Question about Refrigerators
Maytag mfi2569vem will not cool the small fan in bottom is on but nothing else works won't cool the panel on front does work but can't get it to cool
2 Suggested Answers
  • 3 Answers
SOURCE: refrigerator won't cool but the bottom freezer works
under bottom shelf there are air inlets to fridge take out tray clean ice frominlets
Posted on Jul 22, 2012
Testimonial: "You were right on the money! Thank you for saving me $$$. The coils were frozen solid. If this is going to happen again what are the preventative measures I need to take?"
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator won't cool but the bottom freezer works
Jul 22, 2012 | Maytag MFD2560HES Bottom Freezer French...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The bottom of the freezer gets cold , the Fridge gets nothing
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the Bottom is cooling but the refrigerator is not.
To troubleshoot, you must remove the panel that covers the evaporator coil in the freezer. You will need to remove the contents of the lower section of the freezer to get access to the panel near the bottom of the freezer. Once the panel is removed, you should be able to confirm whether the fan is spining. If it does not turn and it is plugged in and the refrigerator is not in defrost mode, then the problem is with the fan motor.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed.
thanks for rating good luck
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
My Maytag MF12568AES Refrigerator is not cooling. May be I need to reset the computer.
This happens to my Maytag like clockwork every summer. The freezer works fine but the refrigerator stops cooling. The first time this happened, it was the fault of the small plastic DC fan that sends cooling from the freezer compartment to the refrigerator section. A technician replaced the DC plastic with an AC metal fan he guaranteed would last the life of the refrigerator. He blamed govt energy standards as the reason Maytag uses the cheap DC plastic fan in the first place. Problem solved. One year later, same issue with no cooling in the refrigerator, freezer fine. Again today, nearly one year to the day! SOLUTION? Trip the circuit breaker or unplug the refrigerator for a minimum of 5 minutes. A reboot now fixes the problem every time. Who would have thought you'd ever have to REBOOT your refrigerator?
Jun 15, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The dividing strip between the freezer & fridge is hot.
Pull the refrig out and remove the rear cardboard panel . Check to see if something is caught in the fan blade stopping it from turning . Also , make sure the black square coils are clean . If the fan is not turning , and no obstruction , replace the fan motor . Use a small house fan to cool the compressor until the motor is replaced or the compressor could stop working .
May 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag French Door Refrigerator not cooling
you have another fan under the ref in the rear that cools the condenser coils you should be able to put your hand in front of thr ref while it running at the bottom front and feel air blowing if not pull the rear cover off and see if the fan is running
Nov 06, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag dryer thermostat
Not 100% about this model, but the stat is located next to the fan.
Remove the front cover - insert a flat blade between the lid and front panel approx 4" in from each side to release the clips, lift the lid, remove the front panel (2 screws) fan and stat at the bottom, rest is straight forward.
May 04, 2008 | Maytag PYE2300AY Electric Dryer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
