Question about Dyson Vacuums
Dyson animal valve o ring - Dyson Vacuums
  • 55 Answers
SOURCE: retractable hose colapses or looses suction
There is a clog either in the hose or the wand/hand
Posted on Dec 31, 2008
jackiaria
  • 350 Answers
SOURCE: Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Posted on Feb 17, 2009
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
  • 20 Answers
SOURCE: DC17 Animal Bagless Upright Cyclonic Vacuum: dyson animal wont turn off...
dyson has switch problems, needs new switch.
Posted on May 06, 2010
  • 10865 Answers
SOURCE: dyson animal not sucking. Have cleaned out all
I had this problem with my DC07 and found the top of the cyclone was stuffed full of compacted dust.
You can (should be able to ) see all way to the top if you look up through the bottom of the center column. If ther's a load of dust up there, you should be able to dislodge a lot with a cane and a good shake.
I actually got to the point where I had nothing to loose, so I actually took the very top plate off the cyclone (3 or 4 Torx screws) and saw a huge plug of dust.
Do please note: Getting the top off and back on again is a **real bugg*r** because of the unlatching mechanism.
Having proved that Dysons **do** clog, I phoned Dyson and got hold of someone technical.
I described as briefly and concisely as I could the problem - top of the cyclone full of dust - and pointed (politely) out that Dyson's advertising stated clearly the machine was supposed never to clog. Ever.
I made no attempt to disguise the fact that my vacuum was out of warranty.
Dyson simply sent me a new cyclone and dust can free of charge!!!
Posted on Jul 28, 2010
I have lost the top to the filter on my Dyson, DC59 GT9-US-FJC3318A. Will you help me get another?
Variant Parts - Dyson
https://www.dyson.com/parts/variant-parts.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Dyson parts for DC59 Animal. Carbon fiber brush bar $22.99 Replacement Carbon fiber brush bar assembly for your Dyson DC59 vacuum cleaner.
Dyson Vacuum and Fan Replacement Parts - Official Site ' Dyson.com
www.dyson.com/parts/select-variant.aspx?category=Cordless
  1. Cached
Find spares and replacement parts for your Dyson vacuum or fan. Select your machine model to see a full ... Dyson Hard DC56. Dyson DC59 Cordless Vacuum ...
Spare parts for DC59 Animal - Dyson
https://www.dyson.co.uk/spares/variant-spares.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Image of Soleplate rollers Soleplate roller pack £1.50 · Image of Wand assembly Wand £55.00 · Image of Crevice tool Crevice tool £10.00 · Dyson Combination ...
Dyson DC59 / DC62 Animal Vacuum Cleaner Parts
www.partswarehouse.com/Dyson-DC59-DC62-Animal-Cordless...s/6871.htm
  1. Cached
  2. Similar
Dyson DC59 / DC62 Animal Cordless Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse.
Genuine Parts and Accessories for the DC59 Dyson Cordless Vacuum ...
https://www.dysonspares.ie/index.php?route=product/category&path=66_285
  1. Cached
Genuine Parts and Accessories for the Dyson DC59 range of Cordless Vacuum Cleaner. owerful handheld vacuum which boasts a brushless switched reluctance motor. It is small, light and powerful. Dyson DC59 Google Search
Dec 26, 2016 | Top Vacuums
My Dyson DC44 animal has the MAX light on all of the time but it appears empty....any ideas?
ring dyson for support it could be the micro particle filter is blocked up and needs cleaning.
Dyson have really good support
http://www.dyson.com.au/support/dc44/dc44-animal-bu/maintaining-your-dyson-machine/wash-the-filters
Sep 10, 2016 | Dyson DC44 Animal Cordless Vacuum
Dyson dc28 animal
Hi there, it's Jack at Dyson.
If your DC28 won't recline into the normal vacuuming position, it's possible that an object such as a pen has been accidentally vacuumed up, and is jamming the changeover valve. To check for this, please unplug the vacuum and lie it on its side, then open the airway inspection port and remove any objects or debris:
This should resolve the issue, but if you would like some further help from our experts after giving this a try, please call us on 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Aug 29, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Why won't my Dyson DC28 animal handle won't tilt down to vacuum
Hi Robert, it's Jack at Dyson.
If you're having difficulty reclining your DC28 from the upright position, it's possible something like a pen or pencil has been accidentally vacuumed up, and is jamming the changeover valve.
Our Support guide should help you check for this: http://www.dyson.com/support/dc28/dc28-animal/using-my-dyson-list/redirect-to-flo-dc07-gen-how-to-remove-a-blockage/flo-dc07-gen-how-to-remove-a-blockage/redirect-to-check-ubend-cover-dc28/check-ubend-cover-dc28
If you'd like some further advice from our experts after you've given this a try, please call us directly on 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Jan 17, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Why won't my dyson Dc28 handle tilt down to vaccum
If you're having difficulty reclining your DC28 from the upright position, it's possible something like a pen or pencil is jamming the changeover valve.
Our Support guide should help you check for this:http://www.dyson.com/support/dc28/dc28-animal/using-my-dyson-list/redirect-to-flo-dc07-gen-how-to-remove-a-blockage/flo-dc07-gen-how-to-remove-a-blockage/redirect-to-check-ubend-cover-dc28/check-ubend-cover-dc28
Jan 10, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Suction only coming through the wand when its replaced its not switching back to the upright. I have a dyson DC28 animal
I'm sorry to hear your DC28 doesn't seem to be working correctly. It sounds as though the change-over valve may be jammed - this diverts the suction to the hose when you remove the wand, and back to the cleaner head when you replace the wand on your machine.
You may find a blockage is jamming the valve - you can check for this using our online Support guide:
http://content.dyson.com/support/help.asp?article=1236&product=DC28-ANIMAL
If you can't find any obstructions, please get in touch with us directly as we'd appreciate the opportunity to provide further assistance. If you email us at askdysonUS@dyson.com, we'll be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
Nov 29, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The brush is slow or won't turn at all on my Dyson animal DC32. I have cleaned everything including the filtres, there doesn't seem to be anything blocking the pipes. I am in Spain and there
Hi Jennifer,
I'm sorry to hear you're having difficulties with your DC32 Animal. If you've been unable to resolve this issue after checking for blockages and washing the filter, I'd encourage you to give the Dyson Spain Helpline a call on 902305530. Alternatively, if you email asistencia.cliente@dyson.com, someone will be in touch as soon as possible to provide assistance.
We'll look forward to hearing from you.
Best wishes,
Jack
Apr 17, 2012 | Dyson DC15 Animal Bagless Upright Cyclonic...
My Dtson Woll no longer stay in the upright posion when off
You must adjust the valve assembly on the right hand side facing the back. It is jamemd and will not allow it to stand up
Dec 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Pressure relief valve opens
Hi.
If the hose works ok then you have A blockage in the section of the machine that goes from the brush roller to the wastebin.
Just remove the soleplate under the machine & check all the airways working back to the wastebin. definately check removeable inspection ports you will probably find omething in them blocking the airway.
http://dysonmanuals.llc.nu/
Jun 25, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
18 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
