Question about Kodak Office Equipment & Supplies
I have a Kodak I260, it gives me a error "SCANNING ERROR-OPERATION ERROR". I've rebooted both the scanner and computer error comes back. I don't know what the error means or what to do next!
SOURCE: benq flatbed scanner error ffff;0024 will not operate or scan
Let me tell you my experience. I've read in one of these many contributions that a person, after many attempts, changed the converter and... IT WORKED. I did the same, as a final attempt, and it worked. Now then, I used a multiple voltage converter with both polarities. I switched it to 12 V, positive in the centre. One more thing: trying to recover my universal AD/DC adaptor, I bought a 12 V, 1 A converter and IT DIDN'T WORK. So be patient
Best regards Carlos
Posted on Apr 11, 2008
  • 14 Answers
SOURCE: Kodak DS3500 scanner
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Posted on Jul 18, 2008
  • 7 Answers
SOURCE: Kodak 3520D scanner Front Scan Mod gain issue
Lamp need to be replace and re-calibrate.
Posted on Jul 20, 2009
SOURCE: Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Posted on Aug 25, 2009
SOURCE: Kodak i260 Scanner
All of a sudden I am getting a double-image when scanning a document. The first part of the image has been moved to the left about 2 inches and the second image on it starts about 4 inches down and about 4 inches from the left. So weird. Any ideas of what could be wrong?
Posted on Apr 06, 2011
IKodak i260 Scanner heating up
the lamp is more than 3 year old , it`s require replace for heat problem
Feb 12, 2014 | Kodak i260 Duplex Color Scanner
Kodak i260 scanner will not install
go for latest, microsoft framework 3.0 download and install before, capture install
Dec 05, 2013 | Kodak I260 Captiva IA-Express Path-Through...
Kodak i260 paper jam
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
Aug 03, 2013 | Kodak i260 Duplex Color Scanner
Kodak i260 error message lamps not stable
it`s problem from adaptor , or from lamp regulator pcb is before conect to lamp wire
Jan 16, 2013 | Kodak i260 Duplex Color Scanner
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
The scanner makes unwanted vertical lines down the document
Clean Optical path to camera lenses back and front, then Calibrate through the Kodak SVTool.
Oct 06, 2009 | Kodak i260 Duplex Color Scanner
Kodak I260 large black line.
It may be inside see this website for how to fix an Hp which is similar http://www.willshak.com/scanner/
Apr 20, 2009 | Kodak I260 Captiva IA-Express Path-Through...
Check kds.log -this is my massage error when i press scan option at canner kodak i 260
My scanner i260 do not scan properly, it present a distortion in the image, Could you help me?
Thanks a lot
Mar 03, 2009 | Kodak i260 Duplex Color Scanner
I260 insufficient memory error
If you start scanning Documents over 17 inch, then its best to swap out the 64mbyte for a 256mbyte card on the mother board cpu 100/110.
You can tell wants loaded by looking at the Info tab in the Kodak Scan Validation Tool.
Nov 03, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak I260 paper tray not lowering after tray emptied
The Kodak i260 has a fixed Paper Tray and does not automatically move up and down?????
Oct 05, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
