Getting Seiki remote access setup code to allow digital channel scan. for SE39FT11 LED TV
SOURCE: UK TV History Freeview Channel
UKTV History now finishes at 18:00, when it is replaced by a new 'cheap-tacky-repeats' channel called 'DAVE'.  Worst thing Free-view has ever done in my mind.
Posted on Oct 17, 2007
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • 718 Answers
SOURCE: setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Posted on Feb 23, 2009
SOURCE: memory loss and inability to channel scan Olevia H537
Reintall the latest firmware and it will solve the problem.
Posted on Apr 07, 2009
How to re-enable inaccessible TV menu options?
Go to thru the main menu until you reach the menu item that says "Reset all".
Jul 18, 2016 | Seiki 39" Class 1080p 60Hz LED HDTV...
Tv has picture on one side only
Maybe 1 of the 2 FCC connectors on the t-con board to the screen or connector on the screen from the t-con board .
Jul 06, 2016 | Seiki 39" Class 1080p 60Hz LED HDTV...
JUST GOT THIS HOOKED UP THIS MORNING,NICE TV.ANYWAY NEED TO HOOK UP MY DVD PLAYER NO VIDEO BUTTON TO CHANCE FROM TV TO DVD WHATS UP? MOVIES WILL NOT PLAY
input source button and what input did you stick the DVD player into was it HDMI1 port cause if it was you would change input source to HDMI1 from DTV input source.
on the tv you have the remote control it has a source button just left of the channel up and down + ch - buttons.
Nov 15, 2015 | Seiki 39" Class 1080p 60Hz LED HDTV...
Cant get dtv highlighted in menue on tv
Your TV must receive a digital signal in order for the DTV option to be available. Since you are not seeing all of the channels when you auto scan then it can be assumed that the signal cable connected to your set is not providing the digital signal. Make sure you are scanning for the proper source of your signal ( Cable TV, Broadcast TV)
Nov 29, 2014 | Seiki 32" LED TV - SE321FB
I have a seiki TV that will scan for channels but won't find any and I have cable with the cord hooked to the TV. help! It won't even allow me to perform any other task on TV other than scanning
Using the TV remote unless you can do it manually switch TV to channel 3, not the cable box the TV, you don't need to scan for channels you do need a cable box though
Sep 28, 2014 | Televison & Video
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
Philips tv stuck on Setup screen
allow the tv to go through the scan make sure there's an aerial pluged in or a vcr playing a tape if you can do that. In most cases when you get this on a TV it needs to find at least 1 channel on analogue or digital and store it in. also make sure there are no buttons jammed on.
Feb 01, 2014 | Televison & Video
Have an old one for all remote 3220 need to know2 how to use the remote to scan for the code
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Aug 19, 2012 | One For All Televison & Video
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
