Getting error code 0017 main motor malfunction
    Sergeant:
  • 401 Answers
Is it still under warranty? Is it still within the store's 30/90 day money back guarantee? If so, then I would return it. Main motor malfunction sounds a bit more severe than just a missing driver.
Posted on Oct 20, 2013
Brother MFC-8440 Machine Error Code 7A - tried to print something and machine stopped, beeped and gave me this code. No resolution from Brother other than to have a tech come look at it. Any insight...
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | Brother MFC-8440 All-In-One Laser Printer
I have a 07 yamaha r1 and im getting 2 codes 22 and 60 and im not getting a throtle response what can it be?
Fault code No. 22 Symptom >> Air temperature sensor: open or short circuit detected.
Item/components and probable cause
1 Connections Air temperature sensor coupler Main wire harness ECU coupler Check the coupler for any pins that may have pulled out. Check the locking condition of the coupler. If there is a malfunction, repair it and connect the coupler securely. 2 Open or short circuit in wire harness. Repair or replace if there is an open or short circuit. Between air temperature sensor coupler and ECU coupler.(Brown/White)(Black/Blue) 3 Defective air temperature sensor. > Replace if defective.
Code 22 > Reinstated automatically if a normal signal is received.
Fault code No.: 60 Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system). Probable cause of malfunction: •Open or short circuit in wire harness. •Defective throttle servo motor (potentiometer circuit). •Stuck throttle servo motor (mechanism). •Stuck throttle servo motor (motor). •Malfunction in ECU. Diagnostic code No.: 01 FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
Jul 13, 2010 | 2007 Yamaha YZF-R1
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
Machine Error 7A and the machine say unplug machine
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
http://www.fixya.com/support/t5660619-7a_error
Nov 25, 2009 | Brother Office Equipment & Supplies
Konica minolta d183 error code C0000
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
Oct 22, 2009 | Office Equipment & Supplies
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA: CALL SERVICE 0017 P MOTOR 2
Our Magicolor 5550. It keeps coming up with the error message: CALL SERVICE 0017 P MOTOR 2 . Any idea as to waht it is
Dec 17, 2008 | Konica Minolta magicolor 5550 Laser...
ERROR 7A
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother laser mcf-8440/ machin error 7a
Oct 26, 2007 | Office Equipment & Supplies
27 people viewed this question
k24674
