I can't remove the needle on my Anders Nicholson Turntable/CD Player/Cassette/Radio
  • 104 Answers
SOURCE: Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Posted on Feb 11, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
  • 104 Answers
SOURCE: The Radio,Cassette Player/Recorder. and CD Player all work. The Phonograph Does Not!
if it arrived by mail then the sender might have screwed the transit screws down to avoid damaging the phono , i am not familiar with memorex but if like most turntables there should be some big screw heads visible on the top of the phono or possibly even under the platter all you have to do is unwind the screws until the platter unit moves freely [you should be able to push it up and down a little bit ]
Posted on May 24, 2009
SOURCE: My Crosley combination turntable/CD/cassette/AM &
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Posted on Dec 10, 2010
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
Anders nicholson 2655 manual
Try Googling (Anders Nicholson)(2655)(manual) without parens.
Jul 29, 2017 | ANDERS NICHOLSON Audio Players & Recorders
Anders Nicholson 2655MO Turntable Cassette CD Recorder 2655 MO Record Player manual is needed
Be sure you are asking about the correct Model number and name, ok?
Here is a link for someone selling that model on eBay.
Maybe you can contact her/him and ... who knows?
Sometimes a person just for no good reason at all, can help.
Who knows?
A
Dec 03, 2016 | Audio Players & Recorders
Where can I find a replacement balance weight for the stylus arm on a Anders Nicholson 2655MMO turntable, cassette, CD player/recorder?
Balance weights can be removed and replaced easily. However when you say it snapped off, that could mean damage to the arm.
If everything is OK with the weight and you still have it, perhaps the weight could be "bodge" back into place. Perhaps with Blue Tack? If after all you can get the arm to balance correctly and apply the correct pressure to the stylus it doesn't really matter how the weight is attached does it? It might take a bit longer to set up correctly, but you might save some money if it needs a complete arm just to replace the weight!
Dec 09, 2015 | Audio Players & Recorders
How do I fix turntable?
If possible, return it as defective.
Sep 13, 2015 | ANDERS NICHOLSON USB Turntable With CD...
How to get a copy of instructions foe anders nicholson E-6906
Request instructions directly from Anders Nicholson.
Dec 01, 2014 | Audio Players & Recorders
I need phongraph needle
If you look at the cartridge it should have a make and model number on it. If you put that into Google the stylus should show up.
May 22, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Need a needle for a spirit of st louis turntable cd cassette player. do not know what kinnd or model to buy
Do you have the old needle?
If so, you can match them up to charts provided by dealers.
If not, try to find out the make / model of the turntable chassis.
Providing some close up photos that would be a big help.
Mar 05, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
53 people viewed this question
 Grubhead
Grubhead
