Question about Panasonic SC-AK240 Shelf System
F61 and when tern on fan dont spin - Panasonic SC-AK240 Shelf System
2 Suggested Answers
SOURCE: on my panasonic sound system
how can i fix m system
Posted on Apr 28, 2011
Is not work it is show f61 what dos this mine and how to fix it
The F61 error on Technics audio equipment will depend on the type of unit. However, it could be a problem with the power amplifier IC or with the cooling fan. (If it's the fan, you might be able to clear the error by pressing and holding the power button until the fan starts to spin.)
Please add a comment with the model number of your audio equipment for more information.
I hope this helps.
Apr 05, 2015 | Technics Audio Players & Recorders
I have the f61 code on a panasonic surround sound. should both fans spin on power up?
Pretty sure both fans should turn. If the unit senses the fan not turning, it will shut down as you are describing. Try taking the label off of the fan so you can see the bearing, and put a couple drops of oil in there. This sometimes get them to turn freely again.
Dec 28, 2012 | Peerless "Panasonic Sc-Ht990 Home...
System won't turn on
F61 is amp error,on these unit the fan must turn when first turned on,see if fan turns when powering up,if not clean fan or spin with hand on start up.if fan turns when first turned on,you have a defective output ic,common on these units.if you have a volt/ohm meter measure the dc voltage across each pair of speaker jacks,if you get anything higher then a few volts,that channel will be bad.However The fans are the most trouble on theses units.
Apr 16, 2010 | Panasonic SC-HT740 System
What does F61 code on my display screen mean?
Hello
Ok, yes, this is a overheating error, but it doen not necessarilly mean that the fan is broken though.
The fan might just be covered in dudst particles, which enables the fan to spin at full speed to enable sufficient cooling.
Just open up the unit, see if the fans actually spin, if they spin, then just clean out the unit of all dust particles, if they are ot spinning at all, just buy 2 new fans, it is cheap.
If the unit is still under warrenty, just send it back, they will repair it for free.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 17, 2009 | Panasonic SC-HT740 System
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Feb 16, 2008 | Panasonic SC-HT995W System
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Dec 05, 2007 | Samsung HT-DS610 System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Panasonic SC-AK240 Shelf System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
