I have a armstrong air ultra 5 tech 91 furnace. When cycling on, I hear no click from the ignitor, then it shuts down.
2 Suggested Answers
  • 306 Answers
SOURCE: armstrong ultra sx 80 furnace
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Posted on Dec 21, 2008
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
Armstrong ultra 93
The blower motor may have to be replaced.
Jul 15, 2014 | Heating & Cooling
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Armstrong GUK125D20-2B won't ignite
Did he check the Pressure switch was it filled whit water can you make the switch open on the pressure switch when blowing on it? Is the hose from the inducer motor opened and not blocked ? also if there is a block after the inducer motor it will not Ignite. If the Tech does not know how to check a pressure switch get a new tech.
Oct 06, 2012 | Honeywell Furnace Air Pressure Switch...
I have an armstrong air ultra v, the ignitor switch or the blower won't come on, we ran the tank pretty low last year, so i'm not sure if we ran out, but we just filled our tank' any suggestions because...
First make sure that your thermostat is turned to heat and auto settings. Then turn up t-stat to where it should be calling for heat.If nothing happens then make sure you have power to heater, gas valve is turned on and blower compartment door is securely latched. If still nothing turn t-stat to fan on and the blower should come on and run until you shut it off. If it does this then you know that you have power to furnace and that the blower works.After you are sure that you have power then remove thermostat cover from base. If stat wires are connected to front of base then disconnect red and white wires and temporairly touch them together. This should send power to your furnace and start the ingnition cycle. If this works then replace thermostat. The sequence of events in the ignition cycle are t-stat calls for heat, induced draft motor comes on and runs for about 20 seconds,then ignitor comes on and lights pilot,then burner lights for 1-2 mins and then blower comes on. I would start at the t-stst and work my way through it. If I can be of any help please ask. Thank you
Nov 28, 2010 | Ruud UBHC Air Conditioner
Hi, My parents have an Armstrong Furnace Ultra V Tech 80 Model #G1N80AR100014B-2A. I am a building engineer with service exp. and have also had a service tech. out. After much research here is my...
You can check the flame sensor with a microamp meter to see if the flame sensor is good unhook the wire going to the flame sensor put one wire lead of microamp meter in the wire and connect the other wire from the microamp meter to the flame sensor the turn on the furnace for a cll for heat if you get less than .9 microamps replace the sensor.
Mar 08, 2010 | Heating & Cooling
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
I have a problem with an Armstrong SX90 gas furnace. model GUK100D14-2B serial number 8497G26541 The ignitor is not 'glowing' and therefore the pilot won't light. Everything seems to be sequencing...
Buy a new ignitor either from the ignitor store online, or your local distributer, Contracter, dealer.. they usually run from 15 dollars to 35. Their simple to change out and deffinite do it yourselfer... Oh and turn off power at breaker panel, you don't need any unexpected surprises!!
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
