Question about Nostalgia Electrics Retro Microwave
Microwave keeps shutting off before food is cooked
Why does it keep running
I have a microwave at work that keeps running after the cook time because it uses the extra time to cool the food so it just spins around the food and the light is on. Check the user manual to see if this is the case with this particular microwave oven.
Jun 05, 2015 | Microwave Ovens
Just had an Adora DVM7195 installed. Every time I try to cook anything, the control panel says "Insert Food". In other words, I cannot get it to cook anything.
try working the directions backwards start command then open door put mug in then use select then time then start
Jan 07, 2015 | In Microwave Ovens
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
I have the Dacor DCM24 microwave and if the table does not spin will the microwave still cook food. I think my turn motor is bad, but wanted to know if I could cook food without it?
Yes! it will continue to cook food, the only difference you may end up with cold spots in the food, rotate plate once or twice to reduce this.
May 30, 2012 | Dacor DCM24 Convection/Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
When we first turn on the microwave there is like a mini-explosion and a fiery spark, but after that the microwave goes through its cycle and cooks the food. But we are afraid to try it again.
pls do not use any aluminum or metal material INSIDE the microwave, this can cause the problem
I assumed, but pls consider the ff info...
Be sure to use nonmetal utensils in the microwave.
For microwave cooking, cut meats and vegetables in uniform sizes to make sure that they cook evenly.
Paper plates, cups, and napkins can be used in the microwave. But don't use foil-lined paper products, paper towels that include nylon or synthetic fibers, or newspaper.
When using plastic roasting or cooking bags in the microwave, discard the wire twist tie and use a plastic fastener or a piece of string instead.
To ensure that food cooks fully and evenly in the microwave oven, stir food and turn dishes periodically while they're cooking.
Jul 25, 2008 | Microwave Ovens
Nostalgia Electrics Retro Microwave Logo
Top Nostalgia Electrics Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Nostalgia Electrics Microwave Oven Expert? Answer questions, earn points and help others
