Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Replacing windows XP
I replaced the windows XP os with a new one. But every time I replaced the existing windows XP the options the system displays earlier win.XPs in the options before the system starts. I want the earlier versions of win XP to e completely removed. But I want the Data stored in the partitioned drives in tact. Can I get the new Win XP OS installed by completely replacing the earlier win XP without getting the data in the partioned drives deleted
    Scholar:
  • 151 Answers
First of all copy your all necessary data from the drive in which you want to install xp in another drive. Then reinstall xp from XP setup CD. At the time of setup it will ask whether to overwrite the present copy of windows or to install a completely new OS or something like that. At that time you select the overwrite option. Remember you install new OS in the drive in which you have old XP.
Posted on Sep 26, 2007
  • 82 Answers
Dear ashwagosha If you replace or upgrade your os the nothing to worry to remove privious version do one thing:-right click on your my computer icon - properties- click on advance tab- go on startup and recovery-setting-select default operating system-edit-delete the old operating path file and save it. bye
How to make default booting OS as Windows XP
in the run box type msconfig now up the top select startup. Now you will see your operating systems to select your default and you can also choose how many seconds it will be displayed for. Cheers from Scott please dont forget to vote
Jul 13, 2010 | Microsoft Windows XP Professional
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Win xp fils missing. how to re install
Run your bootable OS CD and then run the option of repairing the existing OS. All the original files will be replaced with the correct system files and you should get the same looks as it was, originally...................sodeep
Jul 27, 2009 | Microsoft Windows XP Professional
When i on my laptop the log on window start over
hi
i think there is a problem with the operating system
if it is windows and you have the operating system CD then set the bios settings to detect the CD drive as first boot device
insert the windows CD and let it go to the setup area
the first time it asks for the repair or setup select setup
next after it checks for existing windows setup OS and prompts for new setup or repair select Repair - R
this will reinstall all the windows OS again keeping all the existing settings as they are
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Acer Computers & Internet
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
SYSTEM SLOW TO LOAD, OVERHEATING AND CANT GET DRIVER
you can hold down the option key while you start up the computer. It will give you a grey screen and give you choices of startup systems... Choose the Mac OS and see if the start up is quicker. Sounds like the windows xp setup isn't working properly. I'd think elimination of the existing pc partition on the hard drive while running in mac mode and then running Boot Camp according to apple's instructions. Boot camp is on the Leopard OS disc and will get your computer ready to instal windows xp with an authorized xp disc. After it's up and running in windows xp, you can reinsert the mac os disc while running windows and the drivers will be installed for you...it works great... Plus you can download a copy of apple's bonjuer software and it will help you set up your printers to work on your mac as well.... Good luck and let me know if you need more help... KEN
Mar 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Error 0x400 110020000 1005 using recovery disc
use xp os disk and use repair os ...
boot from xp os disk choose install new NOT repair and system will examine and detect that an os already exists and give options continue install new,repair or quit...at this point choose repair..
install new and repair both take around about the same time to complete only repair leaves existing files or downloads previously saved intact and available.also when you install new often you need to find certain software/drivers as windows doesnt install by default (wireless,blutooth,sometimes modem,often vga.) I have my device drivers on a cd for whenever if ever I may need.
once your up and running install a recovery suite that can recover from startup.if you cant find one or dont know of one send ur email and I'll send you the one I use.
then next time you have a software issue you just hit f11 at start and entire hard drive is repaired/recovered in about 5 or 6 min.
Feb 03, 2009 | HP Compaq Presario v3000z Notebook
Problem with botting my system......plese reply
The solution for this issue would be...
In order to get this issue fixed... What needs to be done is as follows...
1) Right click on My Computer...
2) Then in the drop down menu... Left Click on Properties....
3) Then you will get the system properties window...
4) In System Properties Window... Go to the Advanced Tab...
5) Under Advanced Tab Click On Startup & Recovery Tab.
6) Under Startup & Recovery Uncheck the option's which says time to display OS 30 seconds.. Uncheck both the options
Jan 22, 2009 | Microsoft Windows XP Professional
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
