Question about Xerox WorkCentre 228 Laser Printer
Code 43 Xmission server unavailable - Xerox WorkCentre 228 Laser Printer
Tftp server unavailable
Make it available :). The Tftp ip that is programmed in the phone or passed out by a dhcp server is unavailable or unreachable. Tftp is typically how the phone obtains it's config. Does your phone work? You can access the phones settings by holding down the blue key and restarting the phone. There you can verify your settings or change them.
Apr 22, 2014 | Mitel 5330 IP Phone
Server unavailable for activation after update sofware
You may need to reset network settings. General, Reset, Reset Network settings, and just be patient it should activate.
Nov 22, 2013 | Apple iPhone 3GS Black (16 GB)
Am using small business server 2011and and it says http error service unavailable
Hi sebenzile,
The Web server (running the Web site) is currently unable to handle the HTTP request due to a temporary overloading or maintenance of the server. The implication is that this is a temporary condition which will be alleviated after some delay. Some servers in this state may also simply refuse the socket connection, in which case a different error may be generated because the socket creation timed out.
Any client (e.g. your Web browse) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognizes as '503'.
Basically, the Web server is effectively 'closed for repair'. It is still functioning minimally because it can at least respond with a 503 status code, but full service is impossible i.e. the Web site is simply unavailable. There are a myriad possible reasons for this, but generally it is because of some human intervention by the operators of the Web server machine. You can usually expect that someone is working on the problem, and normal service will resume as soon as possible.
You can also contact the system operators of the Web site (e.g. your ISP) to determine why the service is down. They will be in a much better position to help you than I am for this type of error.
Sorry so long winded:)
Hope this helps!
And please rate
Thanks,
Gary
Aug 27, 2013 | Computers & Internet
How do I fix 'server unavailable' problem on HTC
using latest browser or upgrade your browser by latest version
May 16, 2012 | Computers & Internet
Ihave been sending messages and they have been failing. postmaster has been failing, and sending me messages back saying this automatially generated diogsitic problem,diagonostic code is smtp;550
550 error code means the mailbox of the recipient your sending it to either is unavailable(server it is on is down) or the mailbox doesn't exist.
Sep 18, 2011 | Computers & Internet
HI While installing Vedio driver is trowing RPC server unava
Hello sans_sankar,
If it says RPC server is unavailable, that has to do with your internet connection.
Check if both ends of your ethernet or USB cable are properly plugged in their ports on your modem or router to your computer.
You can also turn the modem or router off for a minute then turn it back on again.
Your video installation should be complete, otherwise, it might be incompatible with your computer.
Hope that helps.
Yours truly,
Art Pena
Nov 20, 2009 | Dell Latitude D600 Notebook
Some xbox live contrnt is temporarily unavailable to me
You either do not have an active Xbox Live gold account or Microsoft is having server issues.
Mar 18, 2009 | Microsoft Xbox 360 Console
Server-error-service-unavailable on my hp printer
See this link, I had the same problem and it fixed mine.
http://slayo.com/hp-printers-mac-os-server-error-service-unavailable-or-error-1282-message-when-adding-a-printer-in-mac-os-x.html
Mar 04, 2009 | HP Photosmart C3180 All-In-One InkJet...
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
I am trying to buy on ebay but it is telling me that HTTP 503 server requested is not availible yet I can access it from my PC what is wrong
503 Service Unavailable (HTTP 1.1)
This code means that the service is temporarily unavailable, but should be restored in the future. If the server knows when it will be available again, a Retry-After header may also be supplied.
The above definition means that the server (their end) can't supply the requested information (your end) because it is unavailable (either busy or down). This probably because the server is too busy serving other peoples request. This may also be caused by some firewalls, try disabling it temporarily.
Oct 23, 2008 | Computers & Internet
Xerox WorkCentre 228 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
