Question about Daewoo DWC-056CL Air Conditioner
I have a Daewoo window ac..dwc1220r..i came home one day and the fan was on, the ac was off when I left, nnow I can't turn the fan off,,everything works except when I turn it off the fan stays on..i have to turn off the breaker...sttrangge
Overhead console, AC, windows not working
check all fuses. in both boxes. some cars have 3 boxes
Jan 16, 2014 | 1999 Jeep Grand Cherokee
Ac fan not working
triple posted, and still which of 4 fans..... fail. all can fail.
1: cab heat fan dead, on A./C?
2; evap fan (dead front of car)
3: the 2 engine rad fans dead? behind rad.
so why do i say #3, easy, because if the ECU;PCM detects
problems with engine cooling ,its SMART enough to cut A/C
top lower engine damage, (amazing huh?)
the car is a Franken Daewoo, ad suzuki badged Daewoo POS>
Daewoo could not sell these , So GM when nuts. (really)
but knowing that , opens doors to more books on service.... see?
Dec 12, 2013 | 2006 Suzuki Forenza
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
My cooling fans are not turning on
kick on the ac, if they turn on you know that the fans work, if not replace the fans. If they work its probably the thermal fan switch
Sep 07, 2011 | Daewoo Leganza Cars & Trucks
I have a 2003 Grand Caravan Sport 3.8L. When I turn on my wipers, they'll turn on and eventually shut off - when they shut off, the windows, radio, AC/Fan all go off as well. Restarting the car...
cars r very complex these days--scan car 1st with a tech ll that runs a data stream-other instriments just giv a general direction--probly a module for the wipers needs replacin or reprogrammin
Jul 28, 2011 | Dodge Grand Caravan Cars & Trucks
Daewoo lanos 98 model. Only one radiator fan works, which is overheating the car.
only one is suppose to work the other kicks on when you turn ac on turn ac on does it come on now let me no and i can help you more from there check water level do you have the correct amount of water in resevior of car when car heats up half way fan kicks few minutes later fan should kick off with ac off of course sticking thermostat can cause car to over heat
Dec 08, 2010 | 1999 Daewoo Lanos
My jeep died on me last night. When I got it home and looked under the hood my right side elec fan was completley gone(shattered) and the fan that bolts to the motor in front of it only had one nut left...
I dont have any pics but yes you can reuse the fan if its in good or reusable condition. The electric fan you need for when you turn on your AC it works with your AC.
Dec 05, 2009 | 1998 Jeep Cherokee
A/c fan wont turn on after replaceing parts
This is showing a 98 caravan,is this a window unit?
Oct 06, 2009 | 1998 Dodge Caravan
Aircon works but blows hot air
I had the same problem (during Summer!!) - If you take the Fan/A.C/Temp Control panel off, you'll probably find the plastic bracket that the control cable mounts to, is broken. I just used 3 zip-ties to hold everything in place. 30 minutes work, & 50c parts!! No problems since.
Nov 12, 2008 | 2001 Daewoo Nubira
Daewoo DWC-056CL Air Conditioner Logo
50 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
