Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Registery problem sir,my problem is thta, i changed some settings from the registery through regedit, in winxp sp3. after performing the tweak i restarted the computer, and it failed to boot to desktop. ir runs in safe mode but doesn't runs in normal mode.and i forget the settings that i changed in registery. please guide my how can i get my privious setting. i don't want to format the hard drive.
  • Anonymous Nov 28, 2008
    the problem stated is most the same of the problem i encountered in my p.c. it dosn't boot and a disk read error occured message appeared in the monitor. your help is a big help of me. thank you.
    Scholar:
  • 151 Answers
Its not dangerous to change your registry settings. Go to Start->All Programs->Accessories->System Tools->Backup Click it and it will Backup your system. If this does not solve your problem then you have to reinstall your OS.
Posted on Sep 26, 2007
  • 82 Answers
Dear sunder first of all never change the registery of your system because very senstive.any way restore the system in safe mode from system tool in Accessories. if it does not work then upgrade the os form xp cd.
SOURCE:
Acer6e40e97492 driver
Does XP run OK now? SP3 is an upgrade not an OS
Nov 20, 2013 | Fujitsu Computers & Internet
Tip
How to change your winxp sp2 to sp3
there is some games you can't play in winxp sp2, like gta IV online.
you have to reinstall or format your computer just to turn your operating system in winxp sp3, just to play this game. do'nt waste your time to format or reinstall your hard drive just follow this quick step
Step 1: Run Regedit by Clicking on Start -> Run , type in regedit and press enter
Step 2: Make a backup of your registry (just in case)
Step 3: Browse to "HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlWindows"
Step 4: Modify the value of "CSDVersion" from "0x00000200" (SP2) to the Windows XP SP3 value of "0x00000300"
Step 5: Close registry editor
Step 6: Reboot
Step 7: Start GTA and freakin enjoy it already!
on Jan 16, 2010 | Microsoft Windows XP Professional SP2
Tip
WinXP with NERO8, and SP3
If you have WinXP and NERO v. 8, - then DONT upgrade yor system to SP3.
Your controlpanel disaper, and uninstall of the SP3 is impasible, but, - if you got this problem, do as follow:
"run" regedit, find and delete all nero 8 related issues, it takes about a milion years, but its the only way.
When this is done, and your controlpanel is reachable, delete SP3, and do all the updates for SP2 +.
Then reinstall NERO8 again, and you are back on track.
on Nov 20, 2008 | HP Compaq d530 PC Desktop
I installed a DLink DWLG510 wireless desktop adapter in a PC running WXP SP3 I got the error code 10: this device cannot work. Can you help?
Try uninstalling the driver and software then reboot, and reinstall if that does not work then
Uninstall the driver, software shutdown computer remove card reboot and reinstall. If this does not work it is probably a registery issue.
SO uninstall the driver and software
edit the registery value
click start - run Regedit to open registry editor, be careful to select the right value here.
Navigate to HKEY_LOCAL_MACHINE - System - CurrentControlSet - Enum
now right click on Pci folder and select permissions
click on everyone in this box and check full access
reboot it should solve your problem.
Make sure the encryption you are using on the router is WEP that is what works for this specific card.
Jun 23, 2011 | D-Link AirPlus G DWL-G510 802.11g/b...
Fujitsu USB handydrive is asking for a driver upon connection with a deskdtop running XP SP3. Same SP3 on HP and Toshiba notebooks have not problem recognizing the disk. Is there a special driver need. do...
If your external HD works with other notebooks then the XP SP3 operating system may cause that problem. There may be a driver conflict.
To solve that you should change the drive letter name of your external hard disk. To be able to change the drive letter of it, you can install and run the "Tweak UI" software which is downloadable from the windows website. To download Tweak UI software for windows XP, please click here.
1. After installing and running the Tweak UI you will see the screen below.
You can access your system settings using this tool such as disk drives, and you will be able to change the current settings.
Be careful not to change the other settings.
2. Click on "My Computer > Drive" as shown in the picture below.
And assign another drive letter to your external hard disk (for example checking drive letter F:) and click button "Apply".
3. Then restart your computer to see if it works.
This is one of the solutions that I did before. Your problem may need different solution. This is possible then you can ask again. Fixya experts solve every problem.
But I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu Computers & Internet
Hp pavillion a1120n wont auto read cds
This would mean that autostart is not turned on many programs will turn this on for you like Apples iTunes.
You can turn it off using TweakUI powertool if you use WinXP Home, howeverthe best way is to use a reg tweak to turn it ON however I suggest that you keep it OFF for normal use;
Click Start, Run and enter REGEDIT Then go to:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
Create a new value called: NoDriveTypeAutoRun
Type is: DWORD
Value is: 0x000000b1 (177)
If you use WinXP Professional and feel up to changinf your templates you can enter the Group Policy window.
You should select Administrative Templates \ System in the tree view: grouppol.png You will see an item in the right side pane called “Turn off Autoplay”
Double click the item, and set the radio button to Enabled, and change the “Turn off Autoplay on” to All Drives.
Dec 14, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
How to enable regedit affected by virus
1. go to run - > cmd -> type cd \windows\regedit.exe regedit.com
2. go to run -> type gpedit.msc - > expand User Configuration - > expand Administrative templates -> select system -> on the right side p anel double click prevent access to registery editing tools - > select disabled - > hit apply and ok.
3. Google for hijackthis.exe from trendmicro -> download the application -> execute the hijackthis application -> accept the aggrement ->click on do a system scan and save a log. -> locate option that reads regedit.exe or registry or sounds like referring to registery editing tools -> check mark the option and click on Fix checked.
Try above 3 options one by one if 1st one doesnt resolve your problem.
Best to have a free antivirus like AVG or Antivir to avoid virus issues.
Oct 21, 2009 | Computers & Internet
How to keep number lock on after comuter is shut down and restart
  1. Start the registery editer (regedit)
  2. Go to HKEY_CURRENT_USER \ Control Panel \ Keyboard \
  3. Double-click the value InitialKeyboardIndicators, and enter 2 as it's Value data
  4. Close the registry editor
  5. Log off, or restart Windows for the changes to take effect
Dec 16, 2008 | Dell Inspiron 6000 Notebook
Slow in boot up
MAKE YOUR MENUS LOAD FASTER This is one of my favourite tweaks as it makes a huge difference to how fast your machine willMAKE
This is one of my favorite tweaks as it makes a huge difference to how
fast your machine will 'feel'. What this tweak does is remove the slight
delay between clicking on a menu and XP displaying the menu.
Go to Start then Run
Type 'Regedit' then click 'Ok'
Find "HKEY_CURRENT_USER\Control Panel\Desktop\"
Select "MenuShowDelay"
Right click and select "Modify'
Reduce the number to around "100"
This is the delay time before a menu is opened. You can set it to "0" but
it can make windows really hard to use as menus will open if you just look
at them - well move your mouse over them anyway. I tend to go for anywhere
between 50-150 depending on my mood.
Aug 04, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
