Question about Ovens
New world cooker . lower oven door hinge adrift , just slides in / out Model No DFEO 90
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
SOURCE: oven door on diplomat select 620
We had this problem. You need to buy the door hinges from somewhere, I got them online, and then get someone to fix them on and that fixes the door and glass issue.
Do you have a manual for this, I have changed the sound of the beeper and its too quiet now, and I cant change it back, can you look this up for me?
Posted on Mar 16, 2008
barkencoa
  • 3463 Answers
SOURCE: oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Posted on Dec 31, 2008
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
How to repair hinges on new world oven
Usually doors lift off. You may have to dismantle the door to remove the hinges. Take one to a supplier to get the right hinge.
Jan 03, 2011 | New World G90m Gas Double Oven
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
New world DFEO 70, fan oven not working but top oven is? Why? No power at all on fan oven & no time showing (not lit up)
oven timer seems to be stuck - oven only comes on for about min. and then cuts out to 'pinging'
how do we reset the timer to 000 ?
please
Jan 23, 2010 | New World Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
