Question about Mtd 22" Yard Machine Push Mower
Yard machine 6 speed shift on the go lawn mower will stop moving in speeds 1-3 after the drive belt heats up. speed 5-6 works fine but don't want to mow in 5th or 6th speed.
SOURCE: lawn mower motor just stalls for no reason
Check for water in gas tank and filter.
Posted on May 09, 2009
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
ASE TECH
  • 57 Answers
SOURCE: i have a MTD yard machine ride on mower
Sounds to me like you busted a main drive belt not making any noise from the engine ? just stopped moving if this is correct then you probably looking @ around 45-50 dollars for new belt advanced auto has alot of belts for riding mowers they can assist you with replacing the correct size belt for you mtd.also they can be inexpensive as well on the price of the belts.
Posted on Jan 27, 2010
kel1guy2002
  • 3740 Answers
SOURCE: yard machine lawn mower won't start
Several questions here...
1. Is the oil serviced to the full mark?
The oil level sensor can cause a no spark condition because it grounds the ignition.
2. Is there spark at the spark plug? You can remove the spark plug and test for spark but if the plug is internally grounded it will show spark when removed but if it is installed it can still be defective. (Spark Plugs are cheap replace it)
3. Is the handle safety cable loose even when depressed? A bad safety cable or an improper cable adjustment can also cause a lack of spark.
4. Do you note gas on the spark plug or is it very dry? If the spark plug is dry try adding a splash of gas into the cylinder via the spark plug hole and see if you get a temporary / momentary start. If you do then you have either a fuel supply or carb problem.
Make sure the fuel selector is in the ON position.
5. If you suspect a fuel problem disconnect the tank feed line to the carb and see if there is fuel flow from the tank, No fuel flow no start.... then problem in the gas tank or supply line.
I will post this as a solution but will watch for any responses and continue to assist you if needed.
Thanks for using FixYa.
Kelly
Posted on Jun 17, 2010
What sizes are the drive belt and mower belt on a 1999 agway mtd riding mower with a 12.5 hp briggs?
go to any lawn mower shop they will tell you and get you your belts 45.00 to 60.00 for a belt
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
I changed the deck drive belt & the baldes spin but when I lower the cut height from the highest setting(5) down one (4) the blades spin slows down too much & it's not cutting the grass. I need to...
Sounds like you had to change the belt because their is too much resistance in the shafts that the blades are attached to. This may be from grass. Anyway, that is where I would check, to make sure everything turns freely when not connected to the belt .
May 17, 2014 | Yard Machines 13AN772S000 42-Inch 500cc...
My yard machine 12.5 model 13AC762F729483-839 will not move forward or back whether the engine is running or not.
well the drive system uses belts just like the ones that where used on fans so look at the drive belts for oil and missing sections and the tension
Jul 12, 2012 | Yard Machines 155 Torque Briggs Stratton...
My 2006 mtd yard machine mower has 7 speed on the go shift but the shift is inop mower only goes one speed, what should I look for?
there is a pulley in the center of the tractor that changes size between the two belts they get stuck in on spot when sitting and being let outside
Apr 23, 2012 | Garden
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Bolen lawntractor and it stays in first gear only,it will also go in reverse. I know the belts are not slipping because I put it up to a tree and the wheels spin. I see a rod that goes to the...
It sounds to me that you are expecting this machine to shift thru the gears like an automobile manual or automatic. I believe your machine is working just fine. When you shift into a gear the machine is designed to stay in that gear till you stop, shift into another gear for desired speed, sloww or fast. Try this , I think you will see what I mean. GOOD LUCK.
Jun 17, 2011 | Garden
I have a MTD yard machine ride on mower 42inch(Black beauty) i was cutting grass yesterday and heard a cluck noise and the machine stop moving while the motor was still running. the speed paddle went loose...
Jan 27, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Mtd 22" Yard Machine Push Mower Logo
48 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
