Question about Miele S5281 Callisto Bagged Canister Vacuum
Miele vacuum cuts out - Miele S5281 Callisto Bagged Canister Vacuum
My Miele S 558 hose keeps powering down while vacuuming. I understand that the newer SES 125-3 hoses are supposed to correct the problem. Before I buy, I'm wondering if this has proven to be true.
Debra, Searched the net. and the problem does seam to be poor/faulty circuit board in the hose and the SES 125-3 replacement hose is to be the fix. You could dissassemble first and clean the contacts first, to see if you can correct and extend the life of old hose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
just bought Miele s558 Silver Moon seems like it from 2000 or so If it in...
My Miele S5980 is cutting out How do repair the hose to fix it
Amazon com Miele SES125 Vacuum Cleaner Deluxe Electric Hose Miele Vaccum...
Jul 08, 2016 | Miele Vacuums
I was vacuuming my tumble dryer fluff build up out thoroughly and my miele s5280 cut out. It was obviously overheated but how do i re set it? i cannot see where ther is a reset on the machine or in th...
do not think there is one . try turning the juice off at the breaker then back on .if that doesn't work call a service man not good idea to have a dryer running when vacuuming tho
Mar 04, 2015 | Miele Vacuums
My Miele Vacuum s5980 power cuts in and out?
Go to support on the Miele website. Enter your model number and search trouble shooting for your solution.
murf427
Aug 02, 2012 | Miele S 5980 + SEB 217 Bagged Canister...
S5261 keeps cutting out
How long does it take to cut out? If it is like 10 - 15 minutes it is likely that your filters need replacing. If you are using non genuine miele bags you may be creating an overheating problem also. Of course it could be an actual motor problem as well. Easy way to test is to remove the hose, bag and filters. Turn the machine on and let it run. If it does not cut our it is an airflow problem. Add your bag and filters back in and if it cuts out replace anything that looks dirty. If all good add the hose back on and if you have a problem here you may have a blockage that needs to be removed. If you need any parts for any miele in Australia visit vacuumspot.com.au
May 28, 2012 | Miele Vacuums
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
My Miele S558 vacuum stops working about every 20 seconds (it used toi be every 45 secondsor so) I was told its probably a contact problem, and a replacement hose seems to be the resolution.
Make sure your bag is not full and your filters are clean and unblocked, could be over heating, hence cutting out.
Also test your mains lead, wobble it when its on at the plug and the body end to see if ts cuts out
Sep 28, 2009 | Miele Vacuums
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=640910
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/ Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Miele S5281 Callisto Bagged Canister Vacuum Logo
29 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
