thanks. can you tell me how to get the panel off to access the gear strip/actuator?thanks. can you tell me how to get the panel off to access the gear strip/actuator?
You can't post conmments that contain an email address.
Re: rear window on Toyota 4Runner won't operate up or...
Many electric motors use a nylon gear strip for movement. As the nylon wears it slips and requires help to begin movement. Replacement of the actuator as a unit is probably going to be needed
rear window issue not rolling down?, take your rear window wiper blade and push up to the docking position. Then try the window. The wiper is electrically inline with the window relay. If it is not all the way up (sagging) then your window will not roll down. Hope this helps. Also, the relay board that operate rear window defog, and up/down is located drivers side behind the front seat behind the plastic trim.Next to the fuse box there are two circute breakers,in the center of the two breakers is a small hole take a tooth pick and push into the hole to reset the breaker,if I beleive the rear window breaker is nearest to the fuse box?? this should do the trick.
Likely, is electrical. The switch is relatively primitive and could be a loose connection there or on the motor itself. I've commonly run into the wiring shorting where it enters the tailgate. Thats obviously not going to be easy to reach with the window up, but you can remove the panel from inside the back and get to the motor and all. Best bet is to expose te wires to the switch and see if they are still in circuit with an ohmmeter. If they are, the motor is likely bad or jammed, if not...you have to find the short somewhere. Hope this helps
toyota's are prone to wiring rot. a Local toyota dealer has told me (with the same problem) to chop the middle of the pannel off for the tailgate to get into the wiring. the connectors may have rotted off. if you find a solution, let me know.
I suspect that the back door ECU (the relay box that you speak of) is bad.
Unfortunatly common.
Here is how you check:
With the Key On, you should have 12 VDC in the Solid YELLOW wire going into the box.
Also, You should have power in the solid BLUE wire going into the box.
Operating the switches should transmit power to the BLUE with RED trace, and the VIOLEt with WHITE tracer.
If you have the right power as described abobe, the box is indeed bad. This is a dealer item only, cannot buy one at the local parts store. Sorry. Hope this helps.
