SOURCE: Dehumidifier Present % indicates "Hi"
It is showing high because the present humidity is above 80%. Try turning the humidity setting down and let the dehumidifier run for a while. Once the dehumidifier lowers the humidity in the room this level will go lower. If this persists after running for a while you will need to contact LG for service. They back these models with a 5 year warranty. Here is the number to contact them at:
1 (800) 793-8896
Keep me posted. Thaks - Tech101
SOURCE: My dehumidifier is not working properly. I do not
Yes set unit humidity dial about half way or until it comes on. You need something to measure humidity. most of dials dont have a humidity reading. Set at about 50% Rus
SOURCE: When the dehumidifier is plugged
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
SOURCE: Does not cut off when humidity level reached
I have the same unit and found that a sensor that attaches to the evaporator and the attachment holding it to the coil rusted away. Made a new clip from copper tubing and now it works again.
