Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
Have spark from sparkplug have gas at the carburetor but want start
Why wont my Kawasaki lawn mower start it just cranks has good spark and gas
Is gas getting to the Cylinder? Ethanol Gas ruins carburetors. The Carb might be rusted inside
Aug 31, 2015 | kawasaki Garden
Polaris snowmobile problems
You also need spark compression and vaccume.
Feb 19, 2014 | Winter Sports
900 tiller
what happens if you put a small amount of gas right into the carburetor? if it tries to run on that then you have a carb issue. If it doesn't then I would say you have a spark issue
Sep 25, 2013 | Garden
Replaced sparkplug, solenoid, and battery - riding mower still won't start
check for spark if none remove the harness from the engine and crank it if you then get spark check the safety switches
Apr 22, 2012 | Garden
I just replace the regulator rectifier in 1998 suzuki intruder and it still wont start.
Sir, check your sparkplugs if there is current or electric, you can use sparktester or do it manually out your sparkplug and put it on the top of the head cover of the engine then start the motorcycle if the sparkplug sparks meaning to say electric is ok. check your fuel and your carburetor, bleed your carburetor to check if there is gasoline in the carburetor. thanks, i hope your motorcycle will start.
Apr 28, 2011 | 1998 Suzuki VS 1400 Intruder
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Mar 20, 2011 | Yamaha 2500 Watt Industrial Inverter...
Does not start. what could be the problem?
Make sure the oil level is right. Check for spark by removing sparkplug and reattach the plug wire on it and ground the nut part of the sparkplug on metal on the engine. Whith the switch switch to on you should see a spark between the gap of the sparkplug when you pull the cord. If not get a new plug and make sure it is gapped to 30 thousands. If you are getting spark put the plug back in and tighten and reconnect the wire. Take the air cleaner off and put a spoon full of gasoline in the carburetor and pull the cord. If it fires for a second the carburetor has to be taken apart and cleaned.
Mar 12, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
HONDA GENERATOR GX390-WON'T START-GAS GETTING TO CARBURETOR-NO GAS GETTING TO CYLINDER TO START IT-WHAT IS CAUSING PROBLEM
This can happen if there was fuel left in the carburettor for a few months. The fuel forms a gel in the jets which can block the fuel getting through. You could try the following procedure which might help get it going.
  • Remove the sparkplug.
  • Pour about 5ml (or 1 teaspoonful) of fuel into the opening, where the sparkplug came out of.
  • Dip the end of the spark plug in fuel so the spark gap gets wet and replace the plug and HT lead.
Try to start the generator. The fuel that you poured in should ignite. This might be enough to get the engine running. You may have to repeat the procedure 2 to 3 times. Don't be tempted to pour too much fuel in as it will cause the engine to flood.
If the jets are blocked in the carburettor this might be enough to **** the fuel through but if not you'll need to get a mechanic to strip down the carburettor and clean the jets.
Jan 12, 2011 | V-Twin Horizontal OHV Engine with Electric...
Will not start
Think obwhon on right track like this. It even checks the wiring.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. One short film saves thousands of words. HTH
Lou
Nov 28, 2009 | Garden
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
21 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
