Question about Symantec Procomm Plus 4.8 for PC
Procomm plus 4.8 telnet winsock error - Symantec Procomm Plus 4.8 for PC
Telephony device has been removed...
That means you took the fax modem out, or the drivers are missing
Nov 30, 2013 | Symantec Procomm Plus 4.8 for PC
Software: QWS3270 Secure Discription: WinSock 2.0 Connection closed by host Error performing handshake **** Error 0x80090301 returned by ApplyControlToken Can't connect to pernet1.hoffman.army.mil...
Jolly Giant is a commercial vendor of the QWS320 software.
As such, it provides technical support to registered users of its (originally "Queens university Windows Sockets") software.
Contact them for support.
Also, connect the System Administrators of 'pernet1.hoffman.army.mil', to ensure that their computer is still accepting TELNET/3270 connections from your IP-address.
Sep 01, 2010 | Jolly Giant QWS3270 Plus (qws3270maint)...
Print screen to printer does not work?
try to clear your browsing history, and then check the printer if it is disconnected or disabled.
Mar 02, 2010 | Symantec Procomm Plus 4.8 for PC
REQUEST TIME OUT PROBLEM THEN PING DEFAULT IP 169.254.1.1
The ip address is Static Ipaddress . Tried to do ipconfig /release then ipconfig /renew. Check the ipaddress it should be a different ip address. If your are getting the same 169.254.1.1 ip address . Need to remove and reinstall Winsoc. Backup the registry before performing winsock troubleshooting.
Remove the Winsock Settings
To remove the Winsock settings in Microsoft Windows XP, use one of the following methods, as appropriate for the Windows XP service pack that is installed.
Determine Your Service Pack Level
To determine the service pack level that Windows XP is running, use an account that has Administrator rights and follow these steps:
  1. Click Start, and then click Run.
  2. In the Run window, type sysdm.cpl in the Open box, and then click OK.
  3. In the System Properties window, on the General tab, note the service pack level that appears under System. For example, information that resembles the following may appear:
    Professional
    Version 2002
    Service Pack 2
For Computers Running Microsoft Windows XP Service Pack 2
On a computer that is running Windows XP Service Pack 2, you can use the Netsh command to reset the Winsock settings to the default configuration:
  2. In the Run window, in the Open box, type cmd, and then click OK.
  3. At the cmd.exe screen, type netsh winsock reset catalog, and then press <Enter>.
    The following message appears:
    Successfully reset the Winsock Catalog.
    You must restart the machine in order to complete the reset.
  4. Type exit, and then press <Enter> to quit the cmd.exe screen.
  5. Restart the computer.
For Computers Running Microsoft Windows XP Service Pack 1 and Earlier
To remove Winsock settings from a computer that is running Windows XP Service Pack 1 or from a computer that is running the original release version of Windows XP, follow these steps:
  2. In the Run window, in the Open box, type regedit, and then click OK.
  3. In the Registry Editor window, click the plus sign (+) that is next to HKEY_LOCAL_MACHINE to expand the HKEY_LOCAL_MACHINE registry hive.
  4. Click the plus sign to expand the SYSTEM subkey, click the plus sign to expand the CurrentControlSet subkey, and then click the plus sign to expand the Services subkey.
  5. Under the Services subkey, click the Winsock subkey.
  6. On the File menu, click Export.
  7. In the Export Registry File window, in the File name box, type winsock.reg, and then click Save.
    The Winsock registry subkey is saved in the My Documents folder as winsock.reg.
  8. Right-click the Winsock subkey, and then click Delete.
  9. In the Confirm Key Delete window, click Yes to confirm the removal of the Winsock subkey.
  10. Click the Winsock2 subkey.
  11. On the File menu, click Export.
  12. In the Export Registry File window, in the File name box, type winsock2.reg, and then click Save.
    The Winsock2 registry subkey is saved in the My Documents folder as winsock2.reg.
  13. Right-click the Winsock2 subkey, and then click Delete.
  14. In the Confirm Key Delete window, click Yes to confirm the removal of the Winsock2 subkey.
  15. Quit the Registry Editor program, and then restart the computer.
» Reinstalling the Winsock Settings in Microsoft® Windows® XP
Use an account that has Administrator rights and perform the following steps:
  2. In the Run window, in the Open box, type ncpa.cpl, and then click OK.
  3. In the Network Connections window, right-click Local Area Connection, and then click Properties.
  4. On the General tab, click Install.
  5. In the Select Network Component Type window, click Protocol, and then click Add.
  6. Click Have Disk.
  7. In the Copy manufacturer's files from box, type c:windowsinf, and then click OK.
  8. In the second Select Network Protocol window, under Network Protocol, click Microsoft, click Internet Protocol (TCP/IP), and then click OK.
  9. In the Local Area Connection Properties window, click Close.
  10. Restart the computer.
  11. After the computer has started successfully, click Start, and then click Run.
  12. In the Run window, in the Open box, type cmd, and then click OK.
  13. At the cmd.exe screen, type netsh int ip reset delllog.txt, and then press <Enter>.
The Winsock settings are reinstalled.
Aug 18, 2009 | Motorola CANOPY 2400AP (2400APBC)
Printer only sends paper to tray 1 when printing from procomm...
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
Apr 09, 2009 | HP LaserJet P3005n Printer
Unable to print screen shot
Check reg key:
HKEY_CLASSES_ROOTLocal SettingsSoftwareMicrosoftWindowsShellMuiCache
value name: @%SystemRoot%System32SnippingTool.exe,-15052
value data: Capture a portion of your screen so you can save, annotate, or share the image.
Feb 06, 2009 | Symantec Procomm Plus 4.8 for PC
My procomm plus issue
Procomm Plus and norton 360 are compitable to each other but r not not compitable to work on your operating system .u will just need to format your pc and clean the Procomm Plus files from it and then also delete the norton 360 from your operating system.and then u will be able to reinstall the Procomm Plus after formatting the pc.then instead of norton 360 install any other antivirus software like symantec or avg
Dec 10, 2008 | Computers & Internet
Y-Modem file transfer aborts
Otie, Is this the only unit having trouble? Have you checked your firewall settings? Not knowing the error messege I will just throw my 2 cents in... Have there been any updates to the XP Pro? Has there been any ProComm updates that may have affected the machine. You may need to reset and reconfigure the modem. There could even be some kind of interference at the Telco Office. Just some thoughts, Tim
Feb 02, 2007 | Hawking (UC232S) Serial Adapter
Symantec Procomm Plus 4.8 for PC Logo
95 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
