Question about Bosch Axxis WTL 5410 Electric Dryer
Beko drct 70 w is blowing cold air - Bosch Axxis WTL 5410 Electric Dryer
Beko DRCT 70w condenser dryer not heating inside drum element is new and works any ideas ?
check the 2 thermostats with the element.........if ok.....
check the condenser unit.......they fill with fluff and stop condensing.......i use a hose pipe to shift all the fluff.....
cheers
Nov 23, 2016 | Dryers
Why is my furnace blowing cold air?
I depends on if you have gas or electric heat. If electric, you could have blown a fuse. If gas, your pilot light may be out.
Feb 26, 2015 | Heating & Cooling
Hello I have a Beko DRCT 70w.When i turn it on to
you have a bad air flow problem...try takeing your vent hose of and run a load to see if it dryies faster
Oct 03, 2013 | Dryers
Air is not blowing cold ice on coils
Air conditioning is all about the proper airflow across the condenser and evaporator coil (coil panel). Be sure your filters are clean and there are not any obstructions such as a dirty condenser coil. Also check all tubing and fitting connections for signs of oil which would indicate a refrigerant leak and has now caused the AC to be insufficiently charged.This would cause ice build-up on the evaporator (coil panel) and the out-put of only 70 degrees.
May 31, 2012 | Frigidaire FAS156N1A Air Conditioner
My beko dryer only blows out cold air
test the element or the cycle therm, also the overheat therms,
Nov 16, 2011 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
Bosch Axxis WTL 5410 Electric Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
