Question about Waterway Executive 56 Spa Pump 3hp 2" 2spd 37212211 ()
Discharge has the wrong direction - Waterway Executive 56 Spa Pump 3hp 2" 2spd 37212211 ()
    Top Expert:
  • Waterway Master
  • 6,474 Answers
Make sure wiring is correct
Posted on May 01, 2016
How do I fix a lawnmower That is not cutting but starting
Hi Helen:
I have encountered a similar situation and the problem was that the blade had been installed with the wrong side facing up.
An easy way to check is to look at the discharge opening. Since the grass cuttings have to come out of the opening, the direction of the blade rotation is in the direction that the grass would come out.
With the engine OFF, look under the cutting deck.
The sharp edge of the blade has to be the leading edge as the blade approaches the discharge opening.
If the blade is upside down you will need to unscrew the center retaining bolt, remove the blade, remove the bolt and insert it from the other side, and re- install.
Hope this is the problem as it is an easy fix.
Safety first, Wear Gloves!
Cheers
Apr 12, 2016 | Health & Beauty
Motor rotates in wrong direction and resets in wrong position
Disconnect it from power, press the power button for 10 seconds to discharge it. Now reconnect to power and switch back on.
Nov 21, 2014 | Saeco Talea Touch Plus Espresso Machine
How do i discharge a capacitor?
Let it set overnight is the safest way, put a VOM meter on it (dc volts) to see any voltage is present. You could get a say, ten watt power resistor an place across the terminals to safely discharge the cap. A direct short can be dangerous, cause burns, spark weld the wire or screwdriver to the terminal. Good luck.
Jul 21, 2014 | Dometic Duo Therm RV Air Conditioner Hard...
How do you know if the enpeller is on the wrong way, ya I know no water coming through, but there is air and the motor is in the water.
I presume you're referring to a submersible pump. the impellers are either centrifugal or screw type. Check the direction of rotation by turning the pump on without the impeller installed. Then install the impeller so that the blades can draw water into the pump body and expel it at the discharge discharge outlet.
Oct 06, 2013 | 172550003P Spare Impeller And Shaft
My bike will start a run fine with a jump start but when done riding and try to start the next day noy charge. again starts right up and runs perfect. no stall or nothing not sure how to identify which...
The first thing I would check is the battery. Do a check with a volt meeter and make sure you have 12.5 volts. Then do a load test to see what the CCA's are. If you have a dead cell you can have full volts but not enough CCA's to start the bike. Also check all ground cables and for corrosion.
Apr 04, 2011 | 2002 Honda CBR 600 F(4)i
Water will not drain out of washer
Disconnect the discharge hose from the washer and look for a clog at both ends of the hose. Also, look down where the discharge port is on the washer and clear out the clog there also. If you see no clogs, then make sure your discharge hose is not crimped at such an angle to prevent water from flowing through. Also, make sure your discharge hose is not running on the floor and that it goes vertical straight 4.5 to 5 feet from the floor and then loops directly into the discharge pipe. Give that a shot. Still no water drain? Then the water pump needs to be replaced.
Feb 19, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Jul 03, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
I just bought new rechargeable batteries, and got only a few shots. Why so little usage from new batteries? Is something wrong?
Nothing is wrong with the camera or the batteries. Rechargeable batteries of all kinds will self-discharge over time. Charge them fully (if they are NiMH completely charge and discharge them a few times), and you should see full battery capacity.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Waterway Executive 56 Spa Pump 3hp 2" 2spd 37212211 () Logo
35 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
