Question about Bosch DVR4C1161
Password reset cctv - Bosch DVR4C1161
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
Gamut cctv recorder admin password
To reset password of your CCTV DVR press and hold the ENTER button for 15 to 30 second until the DVR restart's. After the restart you DVR default wizard will come up the same way like if you are setting up the DVR for the first time.
Apr 04, 2017 | Computers & Internet
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
YALE PREMIUM HD720 CCTV DVR
Contact the manufacturer to see if there is a way to reset the account.
Nov 29, 2015 | AccessData Password Recovery Tool Kit (ftk...
How do i re set my qvis cctv system
Open the case. There is a button cell inside. Remove that for about 12 hours with the CCTV disconnected from the mains. The password should be reset.
Feb 20, 2015 | Sharp Qvis Apollo Hd 16 Channel Security...
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
Forgot password zmodo h.264
Is there a reset button? or try 0000-or-9999-or-1234
Aug 22, 2012 | Zmodo 8 Channel H.264 Surveillance...
Reset kguard password
this will get you through the front door Please try this temporary password 519070 to login this will let you get to the admin pass word page so that you can change it i found it on cctv.com page but it takes 7 trys to load the cctv page so im going to post it here for safe keeping
Oct 24, 2011 | KWorld Kguard KG-SHA116 Video Surveillance...
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Televison & Video Logo
24 people viewed this question
Top Bosch Televison & Video Experts
richie46
Bill Boyd
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
