Question about Dishwashers
Stops timing at 29 minute mark. reset and does again at same time
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
This is a timer problem. If the timer is a separate unit, it can be repaired or replaced. If it is on the electronic board..which i doubt very much..the board has to be replaced.
This is only true if the info you give me is accurate.
In which cycle does it stop...fill, wash, rinse, dry...?? That could give some additional clues as to what else could be wrong.
Posted on Oct 17, 2013
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
Hi, I am looking for a timing belt diagram for a 1998 2.5ltr Subaru Outback or can you tell me which timing marks on the sprockets line up to the encasing.
Timing Belt Cover, Belt & Sprockets Removal & Installation 2.5L Engine To Remove:
  1. Remove the drive belts.
  2. Remove the A/C compressor drive belt tensioner. Timing belt & cover DOHC exploded view subaru-03-25-6470.gif
  3. Remove the crankshaft pulley.
  4. Remove the mounting bolts and left timing belt cover.
  5. Remove the mounting bolts and right timing belt cover.
  6. Remove the mounting bolts and front timing belt cover.
  7. Vehicles W/ M/T: Remove the timing belt guide.
  8. Ensure that the timing belt rotation arrows are still visible. If the marks are worn off, place new rotation marks on the belt. Timing belt alignment marks DOHC subaru-03-25-6472.gif
  9. Turn the crankshaft using a breaker bar and special adapter socket on the crankshaft. Align the timing mark on the crankshaft sprocket (1), left intake sprocket (2), left exhaust sprocket (3), right intake sprocket (4) and right exhaust sprocket (5) with the notches in cylinder block and timing belt cover.
  10. Paint alignment marks on the timing belt at the crankshaft and camshaft sprockets timing marks. CAUTION
    Do not turn the camshaft sprockets with the timing belt removed. The valves heads will contact each other causing the valve stems to bend.
  11. Remove the lower right idler pulley.
  12. Remove the timing belt.
  13. Remove the upper right idler pulley.
  14. Remove the lower left (toothed) idler pulley.
  15. Remove the belt tensioner.
  16. Hold the sprocket and remove the left intake and exhaust camshafts.
  17. Hold the sprocket and remove the right intake and exhaust camshafts.
  18. Remove the crankshaft sprocket.
To Install:
  1. Install the crankshaft sprocket.
  2. Hold the sprocket and install the right intake and exhaust camshafts with the mounting bolts. Tighten 58 ft-lb (78 Nm).
  3. Hold the sprocket and install the left intake and exhaust camshafts with the mounting bolts. Tighten 58 ft-lb (78 Nm).
  4. Reset the automatic belt tensioner as follows:
    • Remove the mounting bolt and belt tensioner. NOTE: Do not exceed more than 2,205 lb. (9,807 N).
    • Place the belt tensioner on a press. Press the adjuster rod down gradually (using more than 3 minutes) 66- lb (165 N) or more until the adjuster rod is aligned with the stop pin hole in the cylinder.
    • Insert a 0.08 in (2 mm) diameter pin or hex wrench into the pin hole to lock the adjuster rod.
    • Install the automatic belt tension adjuster with the mounting bolt. Tighten 18 ft-lb (25 Nm).
  5. Install the lower left (toothed) idler pulley. Tighten 29 ft-lb (39 Nm).
  6. Install the upper right idler pulley with the mounting bolt. Tighten 29 ft-lb (39 Nm). Crankshaft sprocket and oil pump cover alignment marks 2.5L DOHC subaru-03-25-4890.gif
  7. Align the timing mark on the crankshaft sprocket with the mark on the oil pump cover. Timing belt alignment marks DOHC subaru-03-25-6472.gif
  8. Align the single timing mark on the right exhaust camshaft sprocket with the notch on the timing belt cover.
  9. When the single timing mark on the right exhaust camshaft sprocket is aligned with the notch on the timing belt cover, ensure that the double lines on the intake camshaft and exhaust camshaft sprockets are aligned.
  10. Align the single timing mark on the left exhaust camshaft sprocket with the notch on the timing belt cover by turning the sprocket counter clockwise (viewed from front of engine).
  11. Ensure that the double lines on the intake camshaft and exhaust camshaft sprockets are aligned when the single timing mark on the left exhaust camshaft sprocket is aligned with the notch on the timing belt cover. CAUTION
    • The camshafts can be rotated independently causing the valves heads to contact each other resulting in bent valve stems.
    • When the timing belt is removed the camshafts will turn to the lowest cam lobe position by the force of the valve springs. Before installing the timing belt the 4 camshafts are in the lowest lift position (valves closed).
    • When the camshafts are rotated to install the timing belts, # 2 intake and # 4 exhaust cam lobes of the left camshafts are held to push their corresponding valves down. In this position, these valves are held in the open position. Right camshafts are held so their cam lobes do not push the valves down.
    • The left camshafts must be rotated from the lowest lobe position to the position where the timing belt can be installed at the smallest possible angle in order to prevent intake and exhaust valve contact. Camshaft sprockets rotation subaru-03-25-6473.gif
    • Do not turn the camshafts in the direction shown in the illustration because the valves will open at the same time and contact each other.
    CAUTION
    If the timing belt alignment is off the mark buy more than 3 teeth, the valves and pistons may have contact.
  12. Align the timing marks on the belt with the marks on the sprockets in the numerical order shown in the illustration.
  13. Install the lower right idler pulley with the mounting bolt. Tighten 29 ft-lb (39 Nm).
  14. Ensure that the timing mark alignment is correct and remove the tensioner stop pin.
  15. Vehicles W/ M/T: Install the timing belt guide and temporarily tighten the mounting bolts.
  16. Vehicles W/ M/T: Measure the clearance between the guide and timing belt. The clearance should measure 0.039 ± 0.020 in (1.0 ± 0.5 mm).
  17. Vehicles W/ M/T: Tighten the guide bolts 7.2 ft-lb (9.8 Nm).
  18. Install and secure the front timing belt cover with the mounting bolts.
  19. Install and secure the right timing belt cover with the mounting bolts.
  20. Install and secure the left timing belt cover with the mounting bolts.
  21. Install the crankshaft pulley.
  22. Install the A/C compressor drive belt tensioner.
  23. Install the drive belts.
Sep 30, 2010 | Subaru Outback Cars & Trucks
How do I set the time on my CAT d1147 wristwatch??
If you press and hold the MODE button, the display will switch to the Time, with seconds flashing. Press the "RESET" button and you can change them.
Press START/STOP and it steps to the minutes, again change the minutes using the RESET button, START/STOP again select hours. Each time you press START/STOP it steps to the next option to change, in sequence:
seconds- minutes-hours-year-month-day-12/24 hr.
How do i remove links from the rubber strap?
Jun 07, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
The Water Star came with no instructions. How do we set the time?
Look at the face of the watch. It should read in very small print which button operates the mode button. Pressing it should change or flash the time, while it flashes, press the button that corresponds with the Start/Stop button to change the hour, press the button marking reset should go to the minutes and so on, when finished press the mode button again.
Sep 13, 2008 | Bulova Watches
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Owen Barnes
