Question about Baby Gear
Little angels swinging crib assembly instructions
Require little angels swinging crib nuts and bolts
SOURCE: Missing parts (pali spa crib set)
I went on dogpile.com (as search engine), the typed in Pali Spa crib...all the information you will need it here!  The phone number the other person gave you is direct to their warehouse...we ran into the same problem...we got a Pali secondhand crib and need a couple of bolts.  Hope this helps!
Posted on Oct 21, 2007
SOURCE: Crib assembly
I need assembly direction for a crib distributed by Jardine Enterprise, LTD. It is model number 0108C00.
Posted on Oct 15, 2008
SOURCE: Jardine Baby Crib Assembly instructions Model #DV601B4
Can you call the manufacturer or visit Babies R Us for the manufacturers phone#? We have the crib you have and so far no issues, fairly easy to assemble
Posted on Jul 07, 2009
Mr_Alejo
SOURCE: Instructions for Little Folks Simmons crib
Geocities is closing down their free webhosting. Simmons crib assembly guide is now available at: http://humm.110mb.com/ under free downloads.
Posted on Jul 19, 2009
SOURCE: Pottery Barn Sleigh Crib Assembly Instructions
We recently put together a PBKids sleigh crib bought on craigslist. the original owner gave us all the old bolts. We actually put the side that DOESN'T say "push" on first. When attaching the "push" side - the one thing we figured out is that you have to fit that side UNDER the rails that are visible on the sides and then pull UP (rather than going down, you have to pull up to fit it in.) that said, the original owner did not give us any bolts/stops to put in the sides that would keep the rail from falling completely to the floor when you push the drop side in. anyone else have suggestions?
Posted on Jul 20, 2009
Need the hooks and bolts for little angels swinging crib
Sorry, best I can tell you is to hold the pieces together and measure the holes both diameter and length. Then go to either your big box or local hardware store and buy the screws and nuts and washers. Of course the screws need to be longer than the holes and purchase Stop nuts (nyloc nuts) so they don't come loose by themselves.
Nov 08, 2016 | Baby Gear
Angel Line Delta 9623 assembly instructions
You can call them and place an order for a manual or go their website. I have had success getting manuals for free but Angel Line seems to be charging for them. Give it a shot by phone, be humble and nice. Maybe they will comp. you one. Angel Line (856) 678-6300 or Manual Order Page click this link. Good Luck
Jan 20, 2013 | Angel Line Dela 9623 / 9625 / 9628 / 9629...
Nuts an bolts for little angles swinging crib
what is the size of the bolts? Pls provide the length of the bolt if available or else if bolt is not available, pls provide with the size of the hole and the length of the holes that the bolt has to pass through. This will determine the size of the Bolts and nuts.
Jan 17, 2013 | Little Angel Baby Care
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
Need instructions on how to assemble a jenny lind drop side crib.
mcdevito75 here, Refer to the packageing for contact details.
Jun 25, 2010 | Angel Line Jenny Lind Crib
Instructions for crib
it's a pain but take the parts of the crib into the hardware store that you need bolts for... make sure the sharp edges are on the outside when you put the bolts in.... i would suggest aircraft bolts... not horridly expensive.... they are the kind that will not come loose on their own.
Robert
Jan 22, 2009 | Baby Gear
Assembling Instructions model 01720-1
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
I have some basic instructions for cribs in general, I hope it helps.
http://www.babeetenda.com/cribinst.htm
Of coarse there may be slight differences. If you listed the brand, I could see if there are proper instructions for it.
Oct 28, 2007 | JCPenney Basic Crib
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
