Question about Panasonic Audio Players & Recorders
Playback issue I'm trying to transcribe a recorded interview, but playback is too fast and high pitched. lowering tape speed and tone only slows it down a little. Do I Need a different cassette player?
Buffalo12980
  • 625 Answers
SOURCE: RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Posted on Dec 31, 2007
SOURCE: Speed
Just had the same problem!!! You have to press FF and Play at the same time to stop the fast play!
This is probably way overdue and you won't even get it, but just in case someone else has this problem...here is the answer!!
Posted on Jan 25, 2008
  • 168 Answers
SOURCE: Malfunctioning tape recorder or bad tape?
How old are the tapes? Unless the tape recorder doesn't shut off when it gets to the end of the tape, then I think the tape recorder is fine and it is probably just the tape.
Hope this helps.
Good luck.
Mac =)
If I have answered your question or at least helped a bit, please remember to leave a feedback or rating.
Thanks.
Posted on Mar 19, 2008
  • 79 Answers
SOURCE: Tape cassette deck - tape speed too fast in reverse mode only
Be sure the pinch roller behind the capstan is moving into place like it should. Otherwise, the take-up drive will pull the tape through faster than it should.
Posted on Mar 21, 2008
  • 145 Answers
SOURCE: tape plays too fast on slowest setting
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
Posted on Nov 08, 2008
Philips 720 transcription tape runs too fast
The deck is bad needs a new worm gear for the functioning motor.
Jan 22, 2014 | Philips PSP-LFH0720/52 Model 720 Analog...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
Just put in my first tape for the 2740. Even SLOW is too fast. I don't see an option for changing it. Am I missing something?
Hello this transcriber is only a 4.8 Speed transcriber and the slide speed control is on the front of the unit if the cassette that you are trying is a Normal 4.8 speed and is not responding you need to send your unit for service you can try this place Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Mar 31, 2010 | Dictaphone 2740 Desktop Cassette...
What is the cue/f play/erase button on the top
When in RECORD, pressing the 'Cue' button will put a tone on the tape. This is used on the transcriber's machine to identify different jobs and such.
When in PLAY, pressing the 'F Play' button will change the playback speed to 1.5.
If you hold the 'ERASE' button and hold the portable in REWIND, it'll erase the tape while it's rewinding.
Hope this helps...
Jul 13, 2009 | Dictaphone Audio Players & Recorders
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Tape plays too fast on slowest setting
May 16, 2008 | Panasonic RR-830 Desktop Cassette...
VHS system malfunction
VCR's automatically detect what speed the present tape was recorded at. It only gives you a choice of speeds when doing the recording. If you are saying that it won't playback a tape recorded in one of the slow speeds, it is most likely because VCR's with more than two heads use different combinations of them in different speeds and the ones used for slow speeds are maybe needing cleaning. If this is the case, the vcr will seem to be playing OK, but the video playback will be bad.
Dec 25, 2007 | Goldstar GVR-DD1 VHS VCR
Speed
Sep 19, 2007 | Dictaphone 2740 Desktop Cassette...
Voice playback is extremely slow.
try with some contact spray ,put it on the speed of tape button and that will solve the problem for some time.
Oct 30, 2006 | Olympus Pearlcorder T1000 Desktop Cassette...
29 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
