Question about Whirlpool GX5FHDXVY Stainless Steel (248 cu ft) Bottom Freezer French Door Refrigerator
How do you remove and replace Drain pan for Whirlpool Refrigerator ICE20, model # GX5FHTXVY00. The drain pan is cracked and needs replacing.
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Can't get to drain pan for cleaning, whirlpool fridge
You can not acces the drain pan. Por 1/4 cup bleach in the defrost drain hole.
Two days later pour 1/4 cup vinegar in the defrost drain hole.
Posted on Mar 19, 2009
  • 163 Answers
SOURCE: Water is leaking in on the refrigerator shelves.
your drain is clogged,take your back panel off and use a hairdryer until all ice under coils is gone.you will know when your drain unclogs water will flow.pour small amount in drain and make sure it flows.turn temp.control off before doing this.
Posted on Mar 20, 2009
louislevel_2
  • 374 Answers
SOURCE: Whirlpool Side by Side Freezer - Ice Build Up in Drain
hi there,
common problem,several factors can be check,check your thermostat setting it maybe too low or you have defective thermostat,if you have good thermostat otherwise the refrigerant charge is to low there could be leak on tube,check your amper rating using clamp ammeter if you got low amper rating recharge freon,but why has low refrigerant there might be leak,repair the leak,before you recharge.hope this solve your problem have a nice day
Posted on Jul 21, 2009
  • 2468 Answers
SOURCE: Drain Pan overflowing and water is leaking in
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Posted on Mar 03, 2011
Why does my GE model number TBX1811 refrigerator leak from the back inside the fridge
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Mar 28, 2015 | GE Refrigerators
Ice in the drain. Where does the drain pipe empty?
Usually into a pan under the condenser coils on the bottom of the refrigerator. Sounds like the drain is pinched or obstructed, since it should drain without a problem. The water is evaporated from the pan by the heat from the condenser coil.
Mar 28, 2015 | Refrigerators
How do i replace a drain pan in an amana refrigerator
The cracked pan is removed and a replacement installed. You may have to do some adjusting to get the old one out.
Sep 18, 2014 | Refrigerators
Fix water leak in water dispenser
  1. Clogged drain
Sep 08, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i remove drip pan from my Amana refrigerator?
The drain pan you seek is not removable, its between the compressor and the condenser coil. if you really need to remove it, you will have to crack it and then replace it with a new one. I hope this answered you question.
Jul 26, 2014 | Amana Refrigerators
A puddle of water comes from under the refrigerator daily. model:ed5gndxw 0, w/o ice maker.
That could be something as simple as a defrost drain line missing the pan below your refrigerator. The drain pan has a hole or crack in it. Or could be the defrost drain line is blocked somewhere else. You mentioned you had no ice maker so I believe you also have no cold water dispenser. I have a link I would like you to click on and read over the different ways a refrigerator leaks, Sea Breeze
Sep 19, 2009 | Whirlpool Refrigerators
Whirlpool drain clog
yes it is most likely the drain that is plugged and or frozen up. to repair this you will need to remove the rear access cover inside the freezer compartment clear all the ice from the drain pan and flush hot water thru the drain hole located in the drain pan. this is a fairly easy repair you can do youself. the hardest part will be removing and reinstalling the rear cover. good luck peyton.
BTW I use a turkey baster or large syringe filled with hot water to flush the drain line with.
Jul 04, 2009 | Whirlpool ED2FHEXMS Side by Side...
Mar 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Whirlpool GX5FHDXVY Stainless Steel (248 cu ft) Bottom Freezer French Door Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
