Question about Heavy Machinery
Vermeer bc1500 schematics
What is the proper belt tension?
How to tighten the belts on my sc252 vermeer stump grinder
How to get a Vermeer Product Manual
Vermeer manuals explain how to safely and efficiently use and maintain your Vermeer machine by referencing your Operation and Maintenance Manuals.
If you are the current owner of Vermeer used equipment, free replacement manuals are available by registering your used Vermeer machine. Your machine Operator's, Maintenance and Parts Manual may be available online. Replacement User's Guides for Vermeer Productivity Tools are also available to those registered and authorized to use the software.
Jul 21, 2017 | Heavy Machinery
How to tighten the belt on a Vermeer BC 1000XL?
The adjustment may be to maximum, renew belt
Feb 02, 2015 | Vermeer BC1000XL
Vermeer 252 wiring diagram
I need a wiring schematics for a 352 Vermeer stump grinder
Jan 14, 2013 | Vermeer 2006 Sc252 Stump Grinder
Where is the tension pully on a 1993 ford taurus 3.0 motor
there is no spring tensioner on some of the 3.0 engines. See instructions below. I will paste a pic on the version that DOES have a tensioner at the bottom of this post.
3.0L Engine-Except SHO
ALTERNATOR BELT WITHOUT AUTOMATIC TENSIONER
  1. Loosen the adjusting arm and pivot bolts.
  2. Turn the alternator belt adjusting screw counterclockwise until the old belt can be removed.
  3. Remove the belt.
To install:
  1. Install the new belt over the pulleys. Check that all the V-grooves make proper contact with the pulleys.
  2. Adjust the belt tension, then tighten the adjusting arm and pivot bolts.
3.0L SHO Engine
ALTERNATOR BELT
See Figure 2
  1. Loosen the nut in the center of the idler pulley.
  2. Loosen the idler adjusting screw until the old belt can be removed, then remove the belt.
To install:
  1. Install the new belt over the pulleys in proper contact with the pulleys.
  2. Adjust the new belt to specifications as follows: Turn the idler pulley nut to the right to tighten the belt to a specification of 220-265 lbs. (980-1180 N). Torque the idler pulley nut to 25-37 ft. lbs. (34-50 Nm).
POWER STEERING AND AIR CONDITIONING BELT
See Figure 2
  1. Remove the alternator belt.
  2. Loosen the nut on the tensioner pulley.
  3. Turn the belt adjusting screw on the tensioner counterclockwise until the belt can be removed, then remove the belt.
To install:
  1. Position the new belt over the proper pulleys, making sure the V-grooves are properly seated.
  2. Install the alternator belt.
  3. Adjust the power steering and air conditioning belt to a specification of 154-198 lbs. (690-980 N) with a belt tension gauge.
  4. Adjust the alternator belt.
3.0L Engine (Except SHO) and 3.8L Engine
VEHICLES THROUGH 1993 WITH AUTOMATIC TENSIONER
See Figures 4 and 5
  1. Insert a 1 / 2 in. breaker bar into the square hole in the tensioner.
On the 3.8L engine, the tensioner has a1/2in. square hole cast into the rear of the tension arm directly behind the pulley. On the 3.0L engine, the1/2in. square hole is cast into the spring housing on the front of the tensioner.
  1. Rotate the tensioner clockwise and remove the belt.
Fig. Fig. 5: 3.8L belt schematic-1993 shown
To install:
  1. Install the drive belt over all the pulleys, except for the alternator pulley on the 3.0L engine for vehicles through 1992, or the idler pulley for 1993 3.0L vehicles.
  2. Rotate tensioner counterclockwise and install the belt over the alternator pulley. Make sure that all the V-grooves make proper contact with the pulleys.
  3. On the 3.0L engine, install the alternator belt for vehicles through 1992.
  4. For 1993 3.0L vehicles, install the drive belt over the idler pulley.
Oct 01, 2010 | 1993 Ford Taurus
2001 lincoln town car belt routing
Continental And Mark VIII With The 4.6L Engine
WARNING
Do not allow the drive belt tensioner to
snap back as damage to the drive belt tensioner or personal injury could result.
  1. Rotate the drive belt tensioner clockwise with a breaker bar installed in
    the 3?8
    inch square hole in the drive belt tensioner.
  2. Lift the drive belt over the idler pulley flange and remove the drive belt.
    To install:
  3. Following the schematic on the decal under the hood, position the belt over
    the pulleys, except the idler pulley.
  4. Rotate the tensioner as described above and install the belt on the idler.
    Ensure that all the V-grooves make proper contact with the pulleys.
Town Car With The 4.6L Engine
  1. Install a breaker bar in the 1?2 in. square hole in the automatic tensioner arm.
  2. Rotate the tensioner away from the belt with the breaker bar.
  3. Lift the old belt over the alternator pulley flange and remove it.
    To install:
  4. Position the new belt over all the pulleys, except the alternator pulley,
    rotate the tensioner as described above and install the belt on the alternator
    pulley. Refer to the belt routing illustration on the sticker located at the
    front of the engine compartment. Ensure that all the V-grooves and all the ribs
    on the belt properly contact the grooves on the pulleys.
  5. Rotate the tensioner toward the belt and remove the breaker bar.
    Fig. 1: Make sure the belt makes proper contact with the pulley
    grooves
    Fig. 2: Accessory drive belt routing - 4.6L engine
Town Car And Mark VII With The 5.0L Engine
Sep 23, 2010 | 2001 Lincoln Town Car
Change a serpentine belt on a 97 lincoln
3.8L Engine
  1. Insert a 1/2 inch flex handle in the square hole in the tensioner. The tensioner has a square hole cast into the rear of the tensioner body directly behind the pulley. Rotate the tensioner clockwise and remove the belt from the pulleys.
NOTE As an alternate method, a 16mm socket can be placed on the tensioner pulley bolt and rotated clockwise to remove the belt.
To install:
  1. Following the schematic on the decal under the hood, loop the drive belt over all the pulleys except the alternator pulley.
  2. With the belt installed properly on all except the alternator pulley, rotate the tensioner as described above and install the belt on the alternator pulley. Ensure that all the V-grooves make proper contact with the pulleys.
4.6L Engine
WARNING Do not allow the drive belt tensioner to snap back as damage to the drive belt tensioner or personal injury could result.
  1. Rotate the drive belt tensioner clockwise with a breaker bar installed in the 3/8 inch square hole in the drive belt tensioner.
To install:
  1. Following the schematic on the decal under the hood, position the belt over the pulleys, except the idler pulley.
  2. Rotate the tensioner as described above and install the belt on the idler. Ensure that all the V-grooves make proper contact with the pulleys.
Apr 23, 2010 | 1997 Lincoln Continental
How do I change the belt on a Vermeer 1230A Chipper?
Here is a link to Vermeer, they should be able to assist you with a diagram or PDF manual.
www.vermeer.com
Feb 10, 2010 | Garden
Serpinten belt instalation i need schematics
Possible wrong belt. Idler arm tension may be broken or weak. Make sure you have the belt properly installed.
Jan 30, 2010 | 2004 Dodge Durango
How do you tighten the belt on a 99 mitsubishi galant ls? there is only one, just changed the alternator and belt is loose, but do not see anywhere to tighten.
yes it is the serpentine belt and there is only one and you need to make sure it is on properly and that it is on the idle tensioner pully andd you have to loosen the tensioner to put the belt on and tighten it to tighten the belt look for a belt schematic on the engine compartment area of your car near the front or sodes on the upper outer area where the hood comes opver the comparment
Sep 01, 2009 | 1999 Mitsubishi Galant
Needing schematics for timing belt on a 2000 se
Removal & Installation
2.0L Engine
  1. Remove or disconnect the following:
    Negative battery cable Spark plugs Catalytic converter Right front wheel Right inner splash shield Accessory drive belt and idler pulley
  2. Rotate the crankshaft to Top Dead Center (TDC) and install Crankshaft TDC Timing Peg T97P-6000-A.
  3. Rotate the crankshaft clockwise against the peg.
  4. Remove or disconnect the following:
    Water pump pulley Valve cover Crankshaft pulley Timing belt covers
  5. Install Camshaft Alignment Timing Tool T94P-6256-CH into theslots of both camshafts at the rear of the cylinder head to lock thecamshafts into position.
  6. Loosen the timing belt tensioner bolt and relieve the tension onthe timing belt by disconnecting the tensioner tab from the timingcover back plate.
  7. Remove the timing belt.
    0900c152801e2a75.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Crankshaft alignment position-Ford 2.0L (VIN 3) engines
    0900c152801e2a76.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Placement of Camshaft Alignment Timing Tool T94P-6256-CH-Ford 2.0L (VIN 3) engines
    0900c152801e2a77.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Timing belt tensioner index marks-Ford 2.0L (VIN 3) engines
To install:
NOTE Always replace the timing belt after loosening or removing it.
  1. Install the timing belt.
  2. Engage the timing belt tensioner tab into the timing cover back plate.
  3. Adjust the timing belt tensioner until the index marks are aligned. Tighten the tensioner bolt to 17-20 ft. lbs. (22-28 Nm).
  4. Remove the camshaft alignment tool and the crankshaft TDC peg.
  5. Install or connect the following:
    Timing belt covers Crankshaft pulley. Tighten the bolt to 81-89 ft. lbs. (110-120 Nm). Valve cover Water pump pulley Accessory drive belt and idler pulley Right inner splash shield Right front wheel Catalytic converter Spark plugs Negative battery cable
  6. Start the engine and check for proper operation.
Apr 08, 2009 | 2000 Ford Contour
Heavy Machinery Logo
94 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
