I have a samsung washing machine WD8704CJZ model and there has been low water pressure from the mains. Most times the water is not sufficient to wash the clothes and I see the error message. I want to find out if I can manually fill the machine with water; say through the detergent area. And what volume of water can I pour per cycle, supposing it is possible?
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
  • 1462 Answers
SOURCE: Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Posted on Aug 13, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
SOURCE: MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Posted on Dec 08, 2009
I have a toshiba washing machine model :aw-sd130sb: error code ec5. But this time solve the problem?
Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
Jan 09, 2018 | Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    Showing F01 error code on readout? what does that mean?
    Hi.
    It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
    With Hotpoint F01 means defective triac or defective motor.
    Aug 18, 2011 | Washing Machines
    On brand new machine the water pressure is ok (not great as we on low pressure) to back of machine but just dribbling out into tub... Model F&P MW612WH 6.5kg
    hi - these machines wioll require sufficient pressure to operate - but low pressure to a certain degree should be fine - takes longer to fill..
    Suggest you double check the hoses to the right valve hot/cold etc - usually there is a filter on the hose and one on the inlet valve, hopefully its not blocked.
    I cannot see any other component that would be faulty - as you say its brand new...
    Jun 24, 2011 | Fisher Paykel EcoSmart GWL15
    Error code ( IE ) on my samsung washing machine model wa13g7q1
    1E - WATER PRESSURE SWITCH ERROR
    * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz
    High Level = 15.00 Khz
    If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
    Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
    You get these messages turned off by fixing the problem.
    Low water pressure is basically one of the valves is not letting water pass through.
    1. Do as you already did and clean the inlet filters. Any kinked hoses?
    2. Adjust the water pressure in the house. Is it too high or too low?
    3. Replace the valves in the unit.
    4. Main board.
    Dec 29, 2009 | Samsung WF448AAP Front Load Washer
    I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
    Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
    Greetings - Thomas
    Jan 16, 2008 | Samsung WF203ANW Front Load Washer
    Washing Machines Logo
    41 people viewed this question
    Top Washing Machines Experts
