Question about XO Vision XOD1760BT Car Video Player
Installed, and when powered up screen is blank except says CAM in upper right corner. checked connections...
Iphone 5 cracked screen repoaced screen now all imget is a blank screenn
If it was replaced via your local Apple Store, it would be covered under a 90 warranty.
If you or a 3rd party replaced the display, then check the connection cables in the upper left hand corner and make sure they are seated correctly. Otherwise, ensure that the display is pushed in all the way and do a "hard reset" (push the power and home button for 10 seconds until an Apple logo appears.
Good Luck!
Nov 10, 2013 | Apple iPhone Cell Phones
CP:B9 issue
That sounds like a power issue. Either your power supply or motherboard is having a problem distriubuting voltage to your computer.
Jul 09, 2013 | IBM eServer xSeries x206m
We have an Electro Brand Inc. DVD Home Theater System, model # STS2891-1. We cannot see ANYTHING on the HDTV screen that would allow us to access the SETUP menu. Please help!!!!!! We have tried...
First, does your TV have HDMI connections? If so, you need to connect your home theater to one of those (it doesn't matter which one, although I would choose HDMI1 (you will, of course, need an HDMI cable for this). You will see nothing on your TV screen until you make that connection. Once you do, using the Electro remote, you should be able to access the "set up" menu.
Jul 15, 2011 | Audio Players & Recorders
How to shut down a computer?
1. Close any applications you have running, such as your email or instant messaging service, by clicking the "X" in the upper-right corner of each program page.
2. Left-click your mouse on the Start button, typically found in the bottom-left corner of your computer screen.
3. Highlight the option to "Shut Down" and left-click your mouse again to initiate the proper shutdown process.
4. Wait until your computer logs you off of any applications, your computer screen goes blank and the power light turns off before you turn off your monitor or close your laptop.
Dec 23, 2010 | Computers & Internet
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
BATTERY IS CHARGED, BUT SYSTEM DOES NOT RECOGNIZE BATTERY
this is a common problem. the battery itself is bad and needs to be replaced
Mar 01, 2009 | Video Game Consoles & Games
Right half of screen blanks out
Hi...there,
Well... after 3yrs of used, it's time to retired. You've got a busted panel...
Dec 01, 2008 | Philips 230W5VS (Silver) 23" LCD Monitor
Olevia 540-B11
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
XO Vision XOD1760BT Car Video Player Logo
19 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
