Question about Texas Instruments TI-Nspire Graphic Calculator
Error domain with solving a poisscdf
I can't seem to find a way to solve poisscdf(x,2,1000)=0.01. I know that i can solve a normcdf by using nsolve(normcdf(x,1000)=0.01,x) but when i try nsolve(poisscdf(x,2,1000)=0.01,x)ill get a domain error, if i simply try a solve, ill get poisscdf(x,2,1000)=0.01 as an answer. How can i solve the equation?
Flortzweich
  • 8 Answers
SOURCE: @ symbol
According to the TI-89 Guidebook:
This notation indicates an “arbitrary integer” that represents any integer. When an arbitrary integer occurs multiple times in the same session, each occurrence is numbered consecutively. After it reaches 255, arbitrary integer consecutive numbering restarts at @n0.
Hope this helps. If you need any more info just ask away! :)
Posted on Jan 30, 2009
onomou
  • 24 Answers
SOURCE: solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Posted on Oct 04, 2009
  • 60 Answers
SOURCE: Argument error whenever I type equations with variables.
Perhaps you have some data stored in the x variable.
With the calculator on, press [2nd] then the minus button. This brings up a list of all the saved data in the calculator. Look through the far left column of the list for x.
If you find x in the list, highlight x, then press F1, and then select delete.
Now it should work like normal.
Posted on Nov 07, 2009
SOURCE: Memory error
You are probably entering the equation wrong. Dont do this: 3600=x(2+2) You have to enter the equation 3600=x*(2+2)
Posted on Dec 30, 2009
  • 102366 Answers
SOURCE: "domain error" message on ti-89 titanium
An argument must be in a specified domain. For example, ans(100) is not valid because the argument for ans() must be in the range 1–99.
Posted on Feb 17, 2010
My invernorm isnt working i cant get any problem to be solved it keeps giving me the error domain menus... how do i fix this?
How about providing the question that your trying to solve and we will work out why your are getting an error.
Good luck.
Paul
Oct 26, 2015 | Texas Instruments TI-84 Plus Calculator
When I attempt to use hyperbolic functions for complex numbers i get a domain error
Have you checked the calculator's manual to see if the calculator is able (natively) to handle functions of a complex argument. It is able to handle simple algebra with complex numbers, powers, roots, solving a polynomial equation.
For this calculator, the hyperbolic functions must have a real argument otherwise you get a error. But just to make sure, try the exponential function with i (imaginary unit) as argument. If it comes back with a domain error you have your answer.
Apr 06, 2011 | Texas Instruments TI-89 Calculator
Activated yahoo mail on my cell. I am not getting email there is an error DNS Error
Yahoo mail with domain other than Yahoo.com seems to have a problem. I noticed this with my iPhone 4G. Try to setup the Yahoo email under generic email account on your cell and not as Yahoo account. Enter all the settings manually.
Hope this solves your problem.
Feb 10, 2011 | Computers & Internet
Network not Joining the Domain using Windows XP
man why dont you just reformat your server and make it Windows Xd and solve your problem.
Jan 21, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Windows cannot connect domain either domain controller is down or otherwise unavailable or because your computer was not found
The resolution and workaround to solve the error is as below.
  1. Login to the Windows 2003 domain controller, and delete the computer account object from the Active Directory by using Microsoft Management Console (MMC) which you can always access from “Manage Your Server”.
  2. Log-in to the PC workstation as local administrator. If you cannot logon as local administrator, try to unplug the network cable and logon to the computer by using a domain administrator user that used to logon on the PC before, by using cached logon credentials feature.
  3. Go to Control Panel, then click on System icon, then go to Computer Name tab.
  4. Unjoin the computer from the domain by clicking on “Change”. You should see that Domain button is now selected. Remember your domain name in the text box. Select (Click) on “Workgroup” to remove the computer from the domain, and put any workgroup name in the text box (e.g. workgroup).
  5. Click OK to exit.
  6. Restart the computer (optional)
  7. Go back to the Control Panel, launch System properties and then go to Computer Name tab, and click on “Change”.
  8. Rejoin the domain by uncheck the Workgroup button and select (check) Domain button, and put in the domain name noted above into the text box.
  9. Click OK to exit.
  10. Reboot the PC.
This should solve the unable to logon to domain error, without changing or losing the user profiles on AD.
Dec 18, 2008 | Microsoft Windows Server Standard 2003 for...
I m using tally7.2 multi user i m getting internal error memory access violaion exiting tally
Dear navin12,
I also got this same problem in my office, first time i solved this problem through restore the XP to Previous restore point. second time this problem came different machine in that machine restore point not worked, I tried all the ways but no use, finally it will work when i login as different Domain user in that machine, I couldn't solve that problem in that particular user.
Oct 22, 2008 | Tally T6218 Matrix Printer
May 11, 2008 | Texas Instruments TI-89 Calculator
Domain error
It's the "Exact/Approx" setting under the [MODE] key. I used to have it on "Exact" and got the domain error issue, but then changed it to "Auto" and it works. IMO, this is a really weird quirk that TI should have ironed out before releasing the TI-89.
Apr 02, 2008 | Texas Instruments TI-89 Calculator
Dec to hex conversion
Not sure if TI-89 mode keys are the same, but here's the solution for that calculator:
1. Hit the mode key
2. Hit F3 to get tot Exact/Approx (might be different for 89T).
3. Set it to Exact.
4. Take a look at T-89 manual pages 327, 328, 329.
Nice of TI to NOT include that in the manual, huh?
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
56 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
