Question about Altec Lansing ATP 3W Computer Speakers
Sliced control cord
I own an Altec Lansing ATP3 and recently, I stupidly/accidentally sliced up the cord from the right satellite speaker where all the controls are located(i.e. turn-on vol, base and treble control). I tried connecting them myself by soldering them but it never worked. I guess its because some wires have the same colors. I really dont have any idea which wire to connect to which wire! Maybe I have interchanged the connections somehow... help please...
  • 2 more comments
  • fmtmendoza Oct 09, 2007
    I have already fixed the wires... I finally got the right connections...
    Thanks for trying to help...
  • Anonymous Dec 09, 2007
    Dogs were NOT made for INSIDE the house and why???? Because their need to chew exceeds the number of worthless items in your house they can destroy without HUMAN anguish. The DONT CARE items in my house have long since been chewed up and thrown away. Now we come to a small matter of a Altec Lancing ATP3 sound cable. You know the one coming from my sound card plugging into the INPUT jack on the woofer?? How do I buy another?? My old sound cable has become MY BEAGLE's latest chew toy.... Anybody want a beagle?? I will swap a Altec Lancing ATP3 Sound Cable for him..... and I hope you live in a steel cage ....
  • Rush31 Feb 15, 2008
    I am looking for left and right speaker extensions...............system is great..had it for years..... at 100$$...can't beat it!!! I just want a bit more seperation.
    Thanks Mark
  •  Rick Labrador
    Rick Labrador Jun 12, 2012
    how did you do it?? i have the same problem.. which wire goes where?? ugh!
  • 363 Answers
Not quite sure how many cores you sliced then soldered. Did you repair a figure-of-eight (two co-axial cables stuck together) or was it two inner wires with a braid over both (round)? Can you give more info or a picture? Just want to help. Regards
Posted on Sep 27, 2007
    Problem Solver:
  • 6 Answers
Obviuosly,the tiny wires inside the insulations have more often than not,red and or white colors and you might have erroneously reconnected them through soldering.Yet,you didnt get the desired result.Visit an electronics spareparts store nearest you but make sure you bring the damaged cord with you,Inquire from them for a compatible cord which you can use as a replacement because if you continue using tis damaged cord might severely affect the entire system.Thanks.
6ya staff
SOURCE:
Where im going to find connectors of atp3
Altec Lansing ATP 3 has 7 pin mini-DIN connector for Right Satellite. You will find that at electronic hardware store. WebRepOverall ratingThis site has no rating(not enough votes)
Sep 19, 2012 | Altec Lansing ATP 3W Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
May 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3 volume control/power know gone bad
hi i used to have the same problem opening the satellite speakers of atp3 (left satellite, the cord was pulled and snap from the inside). i found out how to open them but there's a good and bad news. the good news is i know how to open them, the bad news is that it will cause some damage on your satellite speaker.a friend of mine used to have the same speaker he accidentally drop one of his satellite speaker (left one) and the bottom cover just crack open following the joint line.
the satellite speakers of atp3 has no connecting screws , it is assembled using a sort of super glue. here is how i opened my satellite speaker.
i used a flat screw driver (i sharpened it a bit to easily penetrate the joint) to shove the bottom cover of the speaker starting from the back part (near the cord) then slowly made my way around when the cover start to snap from where i started. you can remove the bottom cover this way but be aware that it will cause some damage on you speaker. i started shoving from the bottom back part because the damage is unnoticed when you reassemble it using a super glue and i use a black paint to hide the discolored plastic casing cause by force opening.
i hope this help a bit
J3n c",)
Mar 26, 2006 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
297 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
