Question about KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill
Burner flame how do you adjust the flame
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
How to adjust side burner on weber grills
Burner could be blocked try cleaning the burner then you should be able to adjust air mix Lpg will a bit of yellow in the flame.
Jun 14, 2013 | Grilling
High flame on burner
the adustment screw should be at the valve.
Jun 14, 2013 | Frigidaire FGFB75D Gas Kitchen Range
Regarding charmglow 720-0289. can't get a hot enough flame. cleaned all burners and made sure all orficis on the burner were clear even blew out with air hose
Are the burner flames diminishing as you turn on additional burners? In other words, is the flame size correct when one burner is lit, but too small when several burners are lit? Is the flame a nice blue color or yellow? If yellow, adjust each burner's air shutter at the end over each orifice. Have you tried adjusting the pressure on your propane regulator? (If it's red, don't mess with it) If it's a silver regulator and has a center cap, you can remove the cap to adjust the screw inside, by turning it clockwise in 1/4 intervals until the desired flame size has been reached. It's also possible that your burners have corroded closed somewhat. Do you have cast iron or stainless steel burners? Cast iron burners tend to corrode shut over the years due to moisture. Stainless steel burners just tend to rust away and flake, but usually become flare ups or out of control flames. Anyway, that gives you some things to look at. Hope it helps. Douglas
Jun 15, 2010 | Grilling
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
BO696 problems-burners too high on lowest position
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Burner does not hold its flame on a Feather 442 stove
IF THE FLAME IS LIFTING OFF THE BURNER, THERE IS TOO MUCH AIR IN THE MIX. LOCATE THE END OF THE BURNER WHERE THE FUEL ENTERS THE BURNER. THERE SHOULD BE AN ADJUSTMENT HOOD THAT CAN BE MOVED TO PARTIALLY BLOCK THE AIR INTAKE. THIS WILL REDUCE THE AIR MIX AND SHOULD MINIMIZE THE FLAME LIFTING OFF THE BURNER.
ON SOME SEALED BURNER COOKTOPS, THE MANUFACTURER RECOMMENDS PLACING A PAN ON THE BURNER AFTER LIGHTING TO MINIMIZE FLAME LIFTING.
IF THE FLAME GOES OUT WHEN SET ON SIMMER,
THERE IS AN ADJUSTMENT SCREW IN THE SHAFT OF THE VALVE ON SOME MODELS. REMOVE THE KNOB TO GAIN ACCESS TO IT. YOU WILL HAVE TO OBTAIN A SMALL SHAFTED FLAT BLADE SCREWDRIVER TO MAKE THE ADJUSTMENT.
Mar 31, 2008 | Kitchen Ranges
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill Logo
Top KitchenAid Grilling Experts
paulcarew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
