Question about Kyocera Mita KYOCERA/MITA - FS-3900DN Mono 37ppm, 400mhz Printer
Kyocera FS-3920DN Ecosys Call Service 2200:0014886 appears more and more
4 Suggested Answers
  • 43 Answers
SOURCE: kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Posted on Dec 16, 2008
n25an
  • 622 Answers
SOURCE: call service 2000:0045345
you have a serious problem with either your main driver motor or you have a broken gear...
Posted on Dec 24, 2009
  • 241 Answers
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
Posted on Jun 09, 2010
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
35 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
