Question about Sony PlayStation 2 (PS2) Console
PS2 disc won't read or turn
All of the sudden my PS2 (slim) won't turn disc. I've listened to the console and makes a clicking sound like it's trying to turn the disc. when I open the disc cover the disc sits in the same position. I've tried all my games (7+) and all the same results.
I'll probably need to service it like you said but I got it temporarly working by bracing it on it's side rather than laying flat. I hope this works a little longer before I really need to serive it because money is tight right now. Thanks Cerfer39
Posted on Sep 27, 2007
  • 709 Answers
Hi Blacknmild, You will not be able to tell the disc is spinning once the door is open. you have to open the slim up and simulate the door being closed by pressing the button switches at the left rear corner of the disc drive, and just behind the reset switch at the same time. Chcek out my repair site www.playstationclinic.com if you need service.
Spindle motor wont spin and lens are clicking ! ps2 slim problem!
seems like you need to go buy a lens cleaner from bestbuy or something. Run it repeatedly untill it works. sometimes it takes a while. But it will work after. please rate@
May 05, 2011 | Sony PlayStation 2 Slimline Console
Tip
How to make sure your disk is inserted properly in a ps2 slim
usually when people are in a rush and they don't realize that they havent put the disk in right in a ps2 slim and it says the disk could not be read. there is a way of checking.when you put a disc into the console make sure you here three clicks. these clicks can be slow or fast. another way to check is probably listening to the playstation when you turn it on.if it continuously clicks that means that the disk isnt inserted properly these two ways save your playstation from the disc overspinning or crashing
please email me if you need more information hrrk13@gmail.com
on Jul 12, 2010 | Video Game Consoles & Games
When i turn on my ps2 slim it makes this clicking sound and then it says "the disc could not be read" please help its annoying
you may need a new laser. the clicking noise is it moving back and forth trying to read the disc, it'll go the end and skip a few times come back and repeat the process until its satisfied that it cant read the disc. replace the laser and you should fix the problem.
Jan 23, 2011 | Sony PlayStation 2 Slimline Console
Screech noise from ps2 slim
Sounds like the laser may have gone bad on your system, try this - use compressed air to clean out the system, where the laser is, and other openings on the device. Then clean your game disc with a CD/Game Disc cleaner (bought at any gaming stores), try this. If this doesnt fix the problems then i would contact SONY and have them replace your system or atleast maybe they could try to fix it. Good Luck!
Jul 13, 2010 | Sony PlayStation 2 Slimline Console
My ps2 makes a clicking sound and gives "disc could not be read"
I had the same problem with mine. it would play the ps2 games just fine but when i put a DVD in, it would click and keep saying reading disc.. i took it apart and gently cleaned the lense with a qtip and now it works fine
Aug 21, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim dose not read some discs
i have encountered these problem with my slim ps2 many times before... the solution for your problem is very easy......
when you insert your disk in your slim ps2 you must hear atleast three quick click sounds, theis sounds represents the cd has been locked in into the driver, to be able to check if it has already locked touch the top part of the cd pertaining to the center part once youve touched it feel if there is no unbalanced portion... if no your ready to play...... if yes reinsert it until you hit the right angle..... these takes a lot of practice just to do it safe for the console and the person..... enjoy...................
Jan 14, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slim problems reading disc
After countless hours of tying to figure this out I went to the basics. This ps2 slim has 3 sensors and after all sensors are the key to making the machine work properly. After testing everything known to man I decided to go around the sensors by taping them all down. Low and behold when I cranked the ps2 slim up the disc now reads and plays perfectly.
Aug 27, 2008 | Sony PlayStation 2 Slimline Console
Im clueless
This sounds like a problem with the DVD player drive and laser. The Drive chip on the slim can overpower the lasers focus and cause heat to build up around the lasers lens. This does absolutely melt the laser lens and its mount. I suggest you replace the entire DVD drive.
If you are not comfortable doing this, click on "Repair Directory" at the bottom of this screen. On the next page, Click on "Video Game Consoles". Select a good Repair shop.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 slim says disc could not be read and it makes a ticking sound
The ticking might be coming from the laser itself. It might be getting too closer to the disc and trying to go farther than it is possible. With the disc out, push the laser from the side all the way away from the center and make the console think that the lid is closed. This may take a few tries before it works. If the problem does not seem like it is coming from the laser you may have a stripped wire that is sparking and should be taking in to be repaired. The latter is possible but VERY rare.
Nov 14, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
137 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
