Question about Vehicle Parts & Accessories
Where is fuse at for fuel pump 93 acura vigor also fuel pump relay
    Habit-Forming:
  • 157 Answers
Where is fuse at for fuel pump 93 acura vigor.? relay is a main relay part# RZ-0067 and is a brownish orange color.
Fuel pump relay is located in the trunk behind the back carpet on the back of the seat. OR
  • located just under the steering column behind the lower panel where your knees would touch if you were driving. it is held on by a 10mm screw.
Fuel Pump Fuse is located under the Dash.
Posted on Apr 21, 2014
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
spiderman699
  • 4 Answers
SOURCE: Does my Toyota camry 93 need the fuel pump fuse or relay to run?
unless some one has riged it so that it will or they are pouring gas down the intake ..yes.
Posted on Mar 03, 2013
How do you get to the fuel pump on 1992 Acura vigor
Unfortunately you have to remove the fuel tank,the pump is in it. It isn't that hard to remove on a lift, and if it is close to empty, it might not be too hard on jack stands and a second support on both sides, at the very least.
Jun 22, 2015 | 1992 Acura Vigor
Fuel problems
could be as simple as a fuel filter if it is in the gas line or it could be your fuel pump or a pinhole crack in gasline good luck hope this was helpful
Mar 07, 2014 | 1994 Acura Vigor
Looking for fuse for fuel pump and relay
fuse should be in fuse box in the trunk and the relay should be in box under hood
Oct 16, 2013 | 1993 Acura Vigor
How can i get to the fuel pump on a 92 acura vigor?
  • REMOVAL & INSTALLATION
  • Print
    The fuel pump on all models except the 1986-90 Integra, is located in the fuel tank. On the 1986-90 Integra the fuel pump is located under the rear of the vehicle, near the drivers side of the fuel tank.
    PRESSURE TESTING
    See Figure 1
    On all models, the fuel pump should run for about 2 seconds when the ignition is first turned ON . By removing the filler cap and listening at the filler, it should be possible to hear the pump run each time the ignition is switched ON . It will then stop again until the starter is activated.
    Fig. Fig. 1: Checking the fuel system pressure
    1. Disconnect the negative battery cable and remove the fuel filler cap.
    2. Relieve the fuel system pressure.
    3. Remove the service bolt and attach a fuel pressure gauge to the top of the fuel filter.
    4. Start the engine and measure the fuel pressure with the engine idling and vacuum hose to the pressure regulator disconnected;
    1986-1989 Integra-35-41 psi. (240-279 kPa) 1990-93 Integra-37-44 psi. (255-304 kPa) 1989-90 Legend-36-41 psi. (250-279 kPa) 1991-93 Legend-38-46 psi. (265-314 kPa) Vigor-43-50 psi. (300-350 kPa)
    1. Check to see that the pressure decreases when the vacuum hose is connected.
    2. If the pressure is higher than specifications, check for a pinched or clogged fuel return hose or faulty pressure regulator.
    3. If the pressure is lower than specifications, check for a clogged filter, defective pressure regulator or leakage in the fuel line.
    4. After inspection, remove the pressure gauge and install the service bolt with a new washer.
    1986-1989 Integra
    1. Disconnect the negative battery cable.
    3. Raise and safely support the vehicle and remove the left rear wheel.
    4. Remove the fuel pump cover bolts and the cover.
    5. Remove the fuel pump mount bolts and the fuel pump with it's mount.
    6. Disconnect the fuel hoses and the electrical connectors.
    7. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    1990-93 Integra and Vigor
    See Figures 2 and 3
    1. On Integra, remove the rear seat and access panel and disconnect the wiring.
    2. Remove the fuel tank.
    3. Remove the pump flange mounting nuts and lift the pump out.
    4. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    Fig. Fig. 2: Removing the fuel pump access cover-Legend and Vigor
    Fig. Fig. 3: Removing the fuel pump assembly-Legend and Vigor
    Legend
    3. Remove the maintenance access cover in the luggage area.
    4. Disconnect the fuel lines and the electrical connectors.
    5. Remove the fuel pump from the fuel tank.
    6. Installation is the reverse of removal. Use new sealing washers when connecting the fuel hoses. After the pump is installed, turn the ignition switch ON and OFF a number of times to pressurize the system and check for leaks.
    Nov 09, 2012 | 1992 Acura Vigor
    Bought a 1992 acura vigor and found horn fuse missing. when I replaced the fuse alarm goes off and constantly sounds. how do I stop it? I've read that there's a relay somewhere under the hood
    horn relay located on the right side kick panel,you will see a row of relays,if horn relay is okay, more likely your horn control pad has a short inside causing horn button contacts to stick causing horn to keep blowing.
    Oct 01, 2012 | 1992 Acura Vigor
    Where is the feul pump located on an 1994 acura vigor? and how to i change it?
    under the back rear passenger seat, The fuel pump itself is located with the fuel pump assembly. Locate the fuel pump assembly top which has 6 bolt with your fuel line and some hose going into. Consider first by reliefing the fuel pressure by taking out the fuel pump relay and starting your engine until it dies first before proceeding to taking out the fuel pump. You then will need to take the fuel line connection out and the hose leading to it, make note of what goes to what connection. Unscrew the bolts, and slowly take your fuel pump assembly out. There you will find a motorize round shape object which is your fuel pump. Take this out. Resintallation is reversal, make sure your fuel relay is installed back on after installation to start your car. I recommend replacing the whole fuel pump assemby, it's less labor intsensive.
    Jan 29, 2011 | Acura Vigor Cars & Trucks
    93 vigor reving in park and dying at stops
    check your fuel tank..you might have bad fuel since it was sitting for awhile
    Apr 21, 2010 | 1993 Acura Vigor
    Location for fuel pump on a 92 acura vigor
    the fuel pump is inside the gas tank.
    Jul 08, 2009 | 1992 Acura Vigor
    1994 Acura Vigor, overheating, fans are not running. Fuse is fine. next step?
    theres a relay that controls the fan, change thermostat and make sure you got 50/50 distilled water , to coolant . your water pump should be checked also. if radiator not clean, then flush it
    Jun 15, 2009 | 1994 Acura Vigor
    93 acura vigor will not start or turnover
    You might need to replace your starter.
    Dec 26, 2008 | 1993 Acura Vigor
    Vehicle Parts & Accessories Logo
    102 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
