Question about Hoover Vacuums
I have a Hoover portapowerS1015 030, on/off switch is intermittent at turning off. Can't find replacement switch, it has been discontinued. Switch number is 12971. Would cleaning the switch help? Does anyone have a used switch?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
OK, yes, try cleaning the swith and make sure contacts are connected to wires, etc. If that doesn't help, try typing "Hoover portapowerS1015 030, on/off switch" in your search engine (eg. google) on your computer to see what you can find online. Usually a number of places may offer it for sale and ship it to you for a small charge. Make sure you compare prices 1st, since the price may vary considerably from one place top another.
Posted on Oct 19, 2013
  • 4 Answers
SOURCE: Hoover Wind Tunnel ON/Off Switch
Replace the rocker switch inside the handle. Part #28161067, it's about $2.50.
Posted on Jul 19, 2008
SOURCE: Hoover Savvy on-off switch does not work (very intermittant)
Hi All-
I found the solution to this issue. You need to take the switch apart. Having a set of small jewelers screwdrivers from radio shack helps a lot.
First, take the switch enclosure off to expose the mechanics of the switch. There are 3 clips on either side that need to be worked free.
There are 4 springs inside the switch that push down 2 metal contacts (one other spring is used to hold the switch in position). If you expand all 4 springs (stretch them out about double there normal size) the increased pressure helps the switch make more solid contact and prevents arching which is what ruins the switch in the first place. After you stretch the 4 springs be sure to clean up the contacts on the switch chassis with a wire brush.
On the slider part of the switch there are 2 contacts which also need to be cleaned up. If you have a dremil tool use it to file a point on opposite the ends of the messed up contact. Be sure there are no burs after making the points . If there are burs the contacts will hang up and springs can't do there job. This is because there are slots the contacts need to float in on the plastic slide.
With the 4 springs stretched out it will be very difficult to put the switch back together. However, with some patients, mini needle nose pliers and jewelers screwdriver set you can be successful.
You may want take the switch circuit board off the vac before putting the switch back together (to do this remove the handle). The switch is much easier to put back together removed from the vac and on a clean well lit table. Assemble the switch in a place where you can find small parts on the floor if the contacts or springs shoot out during reassembly
This hoover savvy runs like a champ now, no more arching in the switch to destroy the contacts.
I would only attempt this if you are mechanically inclined… worst case scenario however is you break the switch and need to order the replacement though… oh yea make sure the thing is unplugged when you do the above procedure.
Dustin
Posted on Oct 10, 2008
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
  • 15 Answers
SOURCE: Hoover power drive u6311 - How do u change switch?
The swrtch is located in the bottom section of the motor. When the swtcih goes out it time to repalce the unit. The swtich is part of the motor. The switch rod run all the way down the body to the swtich located in the motor.
Posted on May 25, 2009
SOURCE: can't switch cleaning mode from tool to floor
there's a mechanism inside the steamvac that should switch the mode automatically when you press the handle release and pull the handle down for the vacuum mode... it's automatic! it took so long to figure out because I kept looking for the switch when it was upright and didn't look as I was using it.
Posted on Apr 13, 2010
I have a Hoover H-28267003, I need the spect for the double swicht
That part has been discontinued. You should take it to your local vacuum repair shop to have it diagnosed. If the switch is actually at fault they can most likely help you with an alternate switch. It may not be the switch , so buying one would be a waste of money.
Jul 03, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
Switch does not turn on or off on hoover windtunnel u458-910
Hoover windtunnel switches can be easily replaced by your local Hoover/Dirt Devil dealer. Have them check the model and serial number to see if yours is under a recall for this issue. You may also have a mechanical plastic rod problem (this operates the switch).
May 02, 2010 | Vacuums
The brushes won't turn. I have turned the switch
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Hoover Steam vac.
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
It is part # 43191008
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover Windtunnel
Take the handle off, then remove the tool holder, then you can get to the switch. Just has tabs on each side of switch, depress them and push it out. These switches will do this after awhile, replacing them is usually the way to correct the problem.
Dec 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Power switch will not work
Hoover U6437-900 U6439-900 Windtunnel Upright
seems there is a short in the power switch, is that possible, I have it disassembled and seems there is power going into the on/off button, but will only sporadically turn on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This could be a defective switch or it could be a loose connection or wire – chances are that it is a defective switch and needs replacement – this could be a slider switch of which does wear out and that is why it will comes on sporadically – if there is a local vacuum cleaner shop in your area they can test the switch and possibly sell you a new one
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
43 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
