Question about Pioneer VSX-823-K
I am not getting any hdmi video output from my Pioneer vsx-823-k. Was working fine but now only getting sound. Tried different cable. Also tried different hdmi input on tv.
SOURCE: Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Posted on Nov 25, 2007
  • 120 Answers
SOURCE: Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Posted on May 20, 2009
  • 6 Answers
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
  • 961 Answers
SOURCE: No picture through Pioneer VSX
Your receiver has 2 HDMI in with one HDMI out, 3 Component in and one out, and two difital optical in. If the bluray player has HDMI out this woukd be your best bet because HDMI carries the audio and video. If it has Component out, you would have to provde sound through the digital optical. Not knowing what blueray player or kind of tv you have, it's hard to advise so I may be over explaining. Anyway, we've touched on the bluray player to receiver. Out of your three HDMI slots on your receiver only one is HDMI out so make sure you're in the right one. Idaelly you have a DVD/blueray in on your receiver so on your receiver you would select "DVD" when playing. If your hook up is correct you may have to try another HDMI cable to test.
Posted on Mar 27, 2011
NO AUDIO
If it is the radio you are trying to get make sure you have an antenna that is strong enough and can receive the signal. With a digital tuner it requires a strong enough signal to capture any channels.
Sep 30, 2014 | Pioneer Vsx-520-k 5.1 Channel 3d Ready...
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
I can not complete my connection HDMI between my TV and my receiver. pioneer VSX 522k. there is no sound, i tried connecting the TV to the receiver no luck, i tried both the TV and Cable to the receiver...
I despise this receiver. It has a mind of it's own and I cannot get it to work. I have had fits for 2 years with the Optical output and TV sound only working every now and then. I am not a sound guy but have competently set up dozens of home systems and worked in bar/restaurant industry dealing with sound systems. This thing is a piece of over or under engineered POS
May 12, 2012 | Pioneer VSX-520-K Receiver
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Pioneer VSX-823-K Logo
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
