Have a Xerox Docucolor 1250 with Fiery X12 Server, and the server has starting freezing during booting up... assuming the operating system on hard drive is corrupted but have no backup to refresh it. Where can I get back this system software? Can someone post a link? Please Help...
  • bohdanjd
    bohdanjd Oct 17, 2013
    To restore from backup do the following:
    1) Power down the Fiery and wait 10 seconds.
    2) Press and hold the 4th key on the right side on the UI (user interface) and power on the Fiery.
    3) Continue to hold the 4th key until the UI reads "Install Software", "Restore Backup", "Install Option" and "Start System".
    4) Select "Restore Backup"
    5) Select "Yes" at the following question "Restore backup configuration?"
    6) This will take approximately 15-20 minutes and the Fiery will reboot 3-4 times.
    7) Once the Fiery comes up to Idle you will need to "Run Setup" and reconfigure the settings.
    Master:
  • 680 Answers
I hope this helps.
Terry
http://www.support.xerox.com/support/docucolor-12/downloads/enau.html?associatedProduct=fiery-ex12&operatingSystem=win8x64
Posted on Oct 17, 2013
FIERY X12 & DC12 NOT CONNECT
In my experience, power both machines down using the preferred method (the copier will either have a sticker on it telling you how to safely shut down, or it may say to just flip the switch, and the fiery server should have a menu screen on the front of it, navigate to the restart option) then power up the Feiry server first, then power up the copier. If you use command workstation, there may be a reboot option as well. Also make sure all network cables are properly seated before rebooting machines. The most common issue is that when the machines are on for a long period of time, the just loose connection, and the reboot re-establishes a connection.
Mar 15, 2011 | Xerox DocuColor 12 Printer
Can you scan to file on the xerox docucolor 12 with the fiery x12 color server
yes it needs one printer cable and one scanner cable connected between fiery and machine
and scangear software install and remote compputer
Apr 23, 2010 | Xerox DocuColor 12 Color Copier
Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
Jun 19, 2009 | Xerox DocuColor 12 Printer
Invalid license problem in fiery x12
if the cdz are genuwine they should be having the key and all registration details,else just clone the old harddisk and restore in your new hdd
what was your reason for changing the harddisk
Apr 22, 2009 | Xerox DocuColor 12 Printer
I am trying to connect xerox dc 12 Fiery x12 to my window vista?
you need to download/install new drivers - http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US
Mar 21, 2009 | Xerox DocuColor 12 Printer
Xerox fiery server
Fiery.1 usually does the trick
Mar 03, 2009 | Xerox DocuColor 12 Printer
Fiery patches
hi better u try to xerox.com/drivers..
Oct 01, 2008 | Xerox DocuColor 12 Printer
Error... the Fiery Server Interface timed out, please, check the Fiery
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is not working, in the Machine Display showing : Error... the Fiery Server Interface timed out, please, check the Fiery. Please help me
Sep 24, 2008 | Xerox DocuColor 12 Color Copier
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
93 people viewed this question
jasbo
jasbo
