Question about Vizio GV42L 42 in. LCD Television
I have a 42 inch Vizio LCD 1080P Gallevia model flat screen. It's coming up in December of 2013 on being four years old. After turning on the TV - ten (10 - 15 minutes) or so, later three-quarters of the screen goes dark, then after a little while, the screen comes back to normal. Also, the screen goes dark from side to side - then will resume back to normal. After doing these two things alternatively, the TV goes back to completely "normal" overall...This just began happening in the last few days - it's Wednesday, 10/16...Does anyone have any ideas what is possibly wrong? Thank you...
    Sergeant:
  • 224 Answers
Sounds like the back light is going out or a connection to the back light has loosened of the years
Posted on Oct 17, 2013
Testimonial: "Hello Kelly: I will get a friend to look at the "back light" or the aformentioned connection. I appreciate the suggest potential problem. If it's a back light going out, and dying a slow death, what does it cost to replace? Thank you! Best regards, Steve"
  • 3 more comments
  • Kelly Oct 17, 2013
    That would depend on your local repair shop, or if you were doing it yourself, the parts can be found online and can range from $25 to $200 depending on who and where you purchase them from.
  • Steve Fischer
    Steve Fischer Oct 20, 2013
    Hello Kelly: What do you think of two TV flat screen repair guys having completely different opinions on my Vizio Gallevia current problem? One says, "it's a bad inverter module - $150.00 or so to fix.
  • Steve Fischer
    Hello Kelly: The second TV flat screen repair guy says, "it a bad LCD screen internally, and not fixable/cost effective, or something to that effect...
  • Steve Fischer
    Hello Kelly: So in essence neither TV flat screen thought it was a loose back light connection, or a bad back light per se...
  • Kelly Oct 20, 2013
    It is always possible to get different opinions on any issue, however without testing the item, all opinions are just opinions based on the symptoms that are described, but it's not a bad LCD since it still works, it's not a bad inverter since the issue is as you described, it's either a cold soldier joint or the back light in my opinion
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: vizio 42 lcd gets large dark spot. it will go away
HI...
It's probably a loose flex cable inside. Look on the web and find someone near you
Have a service tech check it inside for you
Posted on Apr 22, 2010
budmrtn
  • 11361 Answers
SOURCE: every ten to fifteen minutes the screen goes blank
It can be that the 12/24vdc power supply go into shut down mode due to short circuits in the backlight inverter board. You need to check the output voltages of the power supply with and without the backlight inverter board connected to the power supply.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 11, 2010
pastorey
  • 47 Answers
SOURCE: Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Posted on Dec 09, 2010
SOURCE: My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Posted on May 26, 2011
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
I have a 2007 Vizio that after about 4 years began having a startup problem where the screen flashes on and off until it warms up, about 10 minutes on a cold day. For the split second that it is on,
Vizio is a good television. But over the years, the Capacitors will dry up. Flat Panel tv's that come from china use cheap capacitors, even in Vizios. There are monitoring IC's, and if the reference voltage (what the capacitor is supplying to the IC), the set will not turn on, or will be intermittent. Replace the Capacitors on the power supply board and see if set comes on. The Reference IC is a good way of telling if a capacitor is bad. The IC monitors reference voltage in the supply area.
Feb 02, 2014 | Televison & Video
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
When I turn on my Vizio Gallevia 42" tv it Just Shows a Blue screen and no signal then turns off
Have you got anything connected to the TV? If so, make sure they are powered on, and all connected correctly.
Hope this helps
TV_Doctor
Jan 03, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
I cannot switch to 1080p on my Vizio. It is a full HD TV but will not do 1080p and I can't switch resolution off of 480p even with a Blu-Ray.
The resolution is not set at the TV, it is set by the video sources. The TV will detect the resolution and display what it is receiving.
1080P signal = 1080p display.
Does it do that on all sources?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 25, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Thinking about buying a used Vizio 42"
Don't buy it. VIZIO is not standing by their products.
My GV42L had issues from the ssart and now it shows No Signal and shuts of in 2-3 seconds. I read many similar issues on this site with VIZIO.
Sep 27, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
298 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
