Question about Breezaire WK3000 Wine Cellar Cooling Unit
BREEZAIRE WK 3000 NEVER SHUTS OFF AND NOT COOLING
3 Suggested Answers
  • 28 Answers
SOURCE: Inside coils are getting iced up.
One or both coils (indoor and outdoor) are dirty or plugged. Take the unit to a reputable repair shop and have it cleaned and oiled. This should be done at least once a year anyway.
It's possible that it might have a leak. The shop that cleans it can check it for you after they clean it. If this is an old unit, it probably wouldn't hurt to have that done.
Posted on Jul 08, 2009
WCISERVICE
  • 50 Answers
SOURCE: I have a WK Breezaire.
YOU CAN TRY USING A SHOP VAC TO **** OUT BLOCKING MATERIAL OR TO BLOW AIR THROUGH THE DRAIN HOSE TO PUSH THE BLOCKING CONTAMINANT.
BEST WAY IS TO DRILL OPEN THE UNIT USING 1/8 DRILL BIT TO REMOVE THE RIVETS AND TAKE THE COVER OFF, THEN REMOVE THE RIVETS THAT HOLD THE FAN DECK TON ON THE FRONT OF THE UNIT AND TWO ON THE BACK OF THE UNIT TO BE ABKE TO REMOVE THE INSULATION AND EXPOSE THE DRAIN HOSE HOLE, FLUSH WITH LOTS OF WATER AND A BRUSH AND ALLOW UIT TO DRY WELL BEFORE RECONECTING TO THE POWER.
Posted on Aug 28, 2011
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
I have a WK 4000 with the condensation drip line that keeps popping out. What is the best way to fix this permanently?
YOU CAN BUY A NEW DRAIN HOSE FOIR LIKE $15 TO $20 WITH A NEW NIPPLE ON IT AND DO ALL PREVIOUS STEPS EXPLAINED TO UNCLUGG THE HOSE.
Sep 02, 2012 | Breezaire WK 4000 Wine Cooler
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
I have a WK Breezaire. The condensation line is clogged up. I need to get inside the unit to clean out the pan.
Aug 24, 2011 | Breezaire WKL 4000 Wine Cooler
Unit is not cooling. there was dust on the coils that i cleaned off. Now the unit wont cool and there is a dot next to the temperature which is 76
UNPLUG FOR 15 MINUTES AND REPLIUG UNIT IT SHOULD RESET UNIT, DOT IS A DELAY MODE FEATURE OF THE UNIT, YOUR UNIT IS NOT A WKC IT IS A WKCE1060
Jun 19, 2011 | Breezaire WKC1060 Wine Cellar Cooling Unit
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
I have a Breezaire WK6000 which froze up and then stopped working. I am looking for someone to replace and install a new unit
DEPENDING ON AGE OFTHE WK IF IT IS AN R-134 UNIT(CHECK TAG ON BACK OF UNIT) AND IF ITS NOT RUSTED OUT IT SHOULD BE REPARABLE , BUT IF YOU WANT TO REPLACE I WOULD RECOMMEND A WKL MODEL OVER A WKE
Dec 11, 2010 | Breezaire WKE 6000 Wine Cooler
Jul 08, 2009 | Breezaire WKL 4000 Wine Cooler
Breezaire WK3000 Wine Cellar Cooling Unit Logo
110 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
