Question about i-mate K-jam Smartphone
Phone unlocking i have locked manually and fails to open using tabs screen and how can i open it using key pad. i tried but fails there too.
  • 76 Answers
Please explain your issue more clearly and coherently
Posted on Sep 26, 2007
SOURCE:
2000 pontiac Montana passenger sliding door will not open and lock is stuck in the lock position.
If you cannot manually unlock the door, use a rubber hammer and firmly rap the door at the striker/lock area while manually sliding the lock/unlock switch to unlock,it may take a few tries but should unlock.DO NOT lock the door again until you have lubed the lock assembly and are happy with it's operation.If it's an electric lock fail to unlock/lock,with the door open use steel wool on the door post electrical door contact pads once in a while.
Feb 27, 2017 | 2000 Pontiac Montana
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
MY IPHONE IS LOCKED HOW CAN I UNLOCK IT.WHILE IAM COPYING ITUNES TO MY PHONE IT IS LOCKED.ON SCREEN IAM GETTING ONLY THE EMERGENCY CALL KEY PAD AND NOTHING IS THERE.IAM NOT ABLE TO OPEN THE MAIN MENU
Dec 26, 2009 | Apple iPhone 3G
2005 Chevrolet Silverado Automatic door locks
I assume you mean that the central locking system will not lock the doors but you can do so manually.
Get inside the vehicle and close all doors.
On each rear door, lock and unlock the mechanism manually a couple of times. In other words do not use the key pad.
Then leave both rear doors in the locked position (manual locking) and operate the lock button on you key pad to operate the central locking system. Wait a few seconds then hit unlock on your key pad and a few seconds later hit lock on your key pad.
If the system fails to lock your rear doors you will need to get the vehicle to an auto electrician to check out the issue and rectify it for you. There are a number of possible causes which cannot be identified without physically checking the system. So you will need to have this rectified by a professional.
Dec 04, 2009 | 2005 Chevrolet Silverado
Rear doors unlock but will not lock
Automatic door locks will not lock rear doors, they open fine when manually locked but will not lock with switch key fob or when put in gear.
You mean that the central locking system will not lock the rear doors but you can do so manually.
Dec 01, 2009 | 2005 Chevrolet Silverado
My phone says key pad locked how do i unlock it
Try pressing the button right under the display, then follow screen directions. Usually it's a two button sequence such as:
1. Button under display
2. Asterisk key *
If you have the manual, the instructions are there also.
Johnnyczar
Mar 20, 2009 | Lands Phones
Key pad is locked
Download Manual
To unlock your phone:
1. From standby mode, press Unlock (left softkey).
2. Enter your lock code.
Dec 06, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Key pad lock and unlock Nokia 1200
My local Nokia Care Center provided the easy answer (which does not appear in the
owner's manual):
In the Menu, go to Settings, then select Phone settings, and activate "Keyguard Settings," and "Automatic." That done, you must select the time interval until the keypad self-locks. To unlock,
touch the "select" key (upper left key) and * (lower left). That combination also will relock the keypad.
Sep 11, 2008 | Cell Phones
i-mate K-jam Smartphone Logo
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
