Question about Whirlpool WED5100VQ Electric Dryer
Whirlpool dryer WED5100VQ1 will only heat up or run on automatic setting
VOTIT
  • 2071 Answers
SOURCE: dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
docjohn174
  • 943 Answers
SOURCE: whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
Posted on Oct 06, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Posted on Dec 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Posted on Mar 26, 2009
  • 73 Answers
SOURCE: DRYER RUNS BUT NO HEAT
Sounds like you need a heating elemnet. they are easy to replace if you are a little handy.
http://www.google.com/aclk?sa=l&ai=CuXXab_L5SeDSC9CKtgeF_tUO95mrL6ex77AEk4O9wAUIABADKANQrtfXgQJgyY6rjNCkiBKgAcuok_8DyAEBqgQcT9DbhAQFBMTBCzYPlVeDoU63sRdCM1EOByjXsg&sig=AGiWqtylZq9M5TfHU2SxGclHbMEjAopfGg&q=http://www.partstore.com/default.aspx%3Fs%3Dgoogle%26sw%3Dbrand
go to this website,. they will have your "Dryer Heater Element"
Posted on Apr 30, 2009
Need wiring diagram
http://www.appliancepartspros.com/parts-for-whirlpool-wed5100vq1.html
Oct 25, 2015 | Whirlpool WED5100VQ Electric Dryer
What does heating element on a whirlpool dryer model # wed5100vq1 look like
go to either repairclinic.com or appliancepartspros.com and enter your make and model. they will show you a parts diagram and you can see the heating element
Sep 11, 2015 | Whirlpool Dryers
Electric dyer no heat
Online appliance parts sites have been helpful to me. They may help you diagnose the problem and recommend a repair part. It's their business.
Apr 01, 2015 | Whirlpool Dryers
Wed5100vq1 whirlpool
Check the air flow to make sure that it is ok. See if there are any obstructions in the duct work. Technically you should take the temp of the air coming out of the machine.
Jul 21, 2013 | Dryers
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Whirlpool WED5100VQ1 does not heat
Those fuses and thermostats can be checked for continuity with a multi meter. There are several other things that can cause a dryer not to heat. Heating element, burnt wires, improper voltage, inadequate venting, timer, and motor
Nov 03, 2017 | Whirlpool WED5100VQ Electric Dryer
Electric dryer model wed5100vq1 shredded holes in clothes
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 07, 2011 | Whirlpool Dryers
Whirlpool electric dryer model WED5100VQ1 Dryer won't heat and timer dial won't move once it's set on desired dry time. Are these related? Any ideas?
For anyone who may be interested (this post is a little dated). I just diagnosed one of these machines today. Dryer runs with no heat. First thing if you don't have an ohm meter get one and learn how to use it (easy). Check for 220 (240) volts at receptacle then ohm your element then check your thermal cut off( at top of element housing, if these check out good then the timer is the likely culprit ( what I found today). There is a schematic inside the console that shows you what to check.
God bless.
Nov 02, 2010 | Whirlpool WED5100VQ Electric Dryer
Whirlpool WED5100VQ Electric Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
