Question about Refrigerators
Caple CAFF205SS - we have just had this installed but have a problem in that the 'flap' that allows the ice out of the freezer into the cup does not open when the lever is pressed, meaning the ice builds up inside the freezer compartment.
fridgetech
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Posted on Oct 21, 2007
Speed boy
  • 76 Answers
SOURCE: GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
Posted on Sep 10, 2008
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
aborcass
  • 2651 Answers
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Posted on Nov 20, 2008
aasc
  • 1606 Answers
SOURCE: GE Profile Ice flap is broken
The part number you need is WR62X10055 . This is the sokenoid and plunger which operates the flap . They tend to rust badly , keeping the flap from opening/closing . With a small screwdriver , pry the control panel ( from the bottom only ) outwards . This panel is the push buttons for crush , cube , water . Once removed , there are 4 screws , one on each corner of the white housing . Unplug the 3 plugs on the control panel first . Remove the 4 screws and slide out the housing . The solenoid and plunger are at the top right , held on by 3 screws . Replace solenoid AND plunger , and reassemble in reverse . Also , remove the top freezer door hinge cover to access the plug which should be unplugged first . After reassembling dispensor , dont forget to plug the plug back in .
Posted on Aug 08, 2009
The ice flap on my freezer will not stay open. If I reach up and grab the flap as it's opening, the ice will flow freely. But if I don't grab the flap and keep it open, the ice won't dispense. It's no
Kristen,
Thank you for giving more information. I believe you will need to replace the flapper on the ice dispenser. I based this answer on the following: you mentioned when the door is held open ice comes out. Let me know if this helps. As you may know, there are several different things that could cause this issue, but this is the most common one of them. Here is a how to video on this type of repair:
Jul 21, 2014 | Frigidaire Refrigerators
Ice and water keeps coming out
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Feb 09, 2014 | Kenmore Elite 31 cu. ft. Grab-N-Go...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Sounds like marbles or ice dropping in refrigerator (not freezer side). Looking into vent in back upper left corner, noise seems to coincide with a flap going up and down. The flap movement is being...
The flap is what open and closes to allow more or less cold air in from the freezer. There could be ice buildup inside the freezer causing this or a mechanical noise of the flap and motor running. See if you can see it from the freezer side of the vent.
May 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Ice flap doesn't shut
you will need to replace the solonoid its hanging up and not allowing the flap to close
Oct 03, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Plastic ice shoot is broken. How do I remove the old one?
The ice shoot just snapps of of the arm . Pt # 2180224 . Once off , you will see how to snap back on . Usually an ice guide ( ice shoot ) will not allow the flap to close if shoot is broken .
Jul 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
