Question about Aiwa PX-E860 Turntable
Transformer main coil shorted.
What is the voltage output for this Transformer they are 4 different variants 6v 9v 12v and 15v. Ive looked at the service manual on line and it only tells you the input voltage ..being 240v, not what comes after the transformer.
  • madwife Oct 31, 2007
    Thanks for trying but i deliver babies i'm not an electrican, thanks any way it was worth a try.
    Novelist:
    Champion:
  • 382 Answers
You have to do the math according to the circuit path, and all components in between. Break out the voltage meter.
Posted on Oct 28, 2007
Itower speaker system won't turn on
Hi Peter,
1.power switch.
2.power transformer .
3.fuse (if have)
4.rectifier (dc cct)
5.input voltage to transformer.220v ac or 110v ac.
6.output voltage from transformer .(low ac value 12v 9v 7.5v....)
7.voltage in smoothing capacitor.according to transformer voltage 12v,7.5v etc....
power switch and switching power.
regards,
nuwan
Jan 27, 2014 | Apple Soundlogic Itower Speaker Works W/...
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
Feb 18, 2013 | Televison & Video
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
My self diagnosis problem. (standby)imdicator is flashing in red,six times between two second break ??????
Information from Sony:
Audio Output Error (6X)
There are three possible failures that can cause a 6X protection mode, and they are as follows.
Short Audio Amplifier Outputs
Lose of 15V Supply
Lose of 9V Supply
The key to determining what to check first is if audio is heard before the TV shuts OFF.
If audio is heard before the TV shuts OFF, then the next step is to check the 15V supply at CN7503/pin 1. If the voltage is missing replace the G1/G2-Board. If the voltage is present, first check the fuse PS7001 for a possible easy fix. If the fuse is OK replace the AU-Board.
If no audio is heard before the TV shuts OFF check for 9V at CN9502/pin 1.
If the 9V is missing replace the BU-Board. However, if the 9V is present check and confirm that the protection circuit output voltage is making it to the Main Microprocessor IC1001/pin 26. If 2.8V is present at IC1001/pin 26 then the Main Microprocessor is defective. Replace the BU-Board. If the voltage at IC1001/pin 26 is 0V then the audio output circuit has actually failed. In this case, replace the AU-Board. A shorted audio output or a DC voltage level measure across the audio output will cause a 6X protection mode indication. In either case the problem will exist in the audio circuitry on the AU-Board.
May 24, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Replacment adaptor
Look at the old adapter if you have it. Match up the voltage requirement. and meet or exceed the current (mA) rating. also make sure it is DC if required. Any adapter that has the right voltage and current output will work. Also you can go over the voltage but like 20% ie: 12V works for 9V, and 15V works for 12V and so on. But if you go under the voltage requirement, only do so by 10 percent. And increse the current requirement proportionally. Chances are you have an old adapter around that you are not using. If you need to change the connector, the wire with the white stipe on it is usually positive. So long as you match them up you should be ok.
Dec 21, 2009 | Durabrand PDV-709
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
Aiwa PX-E860 Turntable Logo
165 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
