Question about Dryers
SAMSUNG DRYER DV210AEW/XAA WILL TURN ON BUT NOT START
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 3074 Answers
SOURCE: I have a samsung dryer mod DV218AGB/XAA. The dyer
maybe the belt:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Nov 29, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
  • 146 Answers
SOURCE: i have Samsung-7.3 Cu. Ft. 7-Cycle Electric
i would take the plug panel off the back and make sure you are getting the full 220 volts on the terminal,, (it could be in the cord itsself), if that is not your issue, it might be your main board, since it is new i wouldn't tear into it because it will void the warranty
Posted on Jan 28, 2011
My Samsung dryer (model #DV210AEW/XAA) will turn on but will not work. Its shows a symbol that is shown below Temp. & Time.
that is your child lock. if you hold down the temp and time buttons for about 5 seconds, at the same time, the light should go out and unit should work like normal.
Nov 15, 2015 | Samsung Dryers
Samsung dryer model DV210AEW/XAA it isn't too now we're restart button is
here is the manual for your model. good luck
http://www.samsung.com/us/support/owners/product/DV210AEW/XAA
Aug 26, 2015 | Samsung Dryers
Dryer not heating
This problem could be one of many components , heater, t hermostat, thermal fuse, control board, wiring you would need to be noledgable about volt ohm meter to diagnose this problem . but try this turn breaker at panel off and back on this will reset the computer
Mar 24, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
DV210AEW/XAA won't heat
More than likely the element is shorted or the thermal cutout on the element assm has failed you can test them for continuity if they don;t have continuity they are bad. 1st reset your house breaker, the dryer needs a full 220volts to turn the heater on, if that is good check the cord and make sure you haven't lost 220 there, then check the element and cutout.
Jan 17, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Dv210aew/xaa
odds are the heating element opened or the hi limit or the safty thermostat
Sep 03, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
My Samsung DV219AGW/XAA dryer has no error codes. The panel comes on, but it doesn't start drying.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2011 | Samsung Dryers
I have Samsung-7.3 Cu. Ft. 7-Cycle Electric Dryer-White-DV210AEW/XAA SKU: 9739916 this is my first time using this dryer just got it opened the door to check the dryer and closed the door pushed the power...
Jan 28, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
Dryers Logo
294 people viewed this question
Top Dryers Experts
