Question about Samsung YP-S2 MP3 Player
I accidentally deleted the drivers n folders in my Samsung YP-S2 mp3 player. The computer cant find it when I put it in the usb hub now. what and where can I go to get the full drivers etc back
Cupatincho
SOURCE: samsung yp-u3j ZB/XEU freezing/computer not recongising after i deleted files from the device
Hi...I find the answer...Push and hold rec button and button for holding...And it will start..
Posted on May 23, 2008
  • 6 Answers
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Posted on Jul 11, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: disconnected samsung mp3 player
Gday...the most likely issue concerning the "USB Disconnected" message on the U3 is that the device has installed itself with incorrect drivers. If this is the case then following these steps should rectify your problem...
1) Plug the MP3 player into the USB port
2) Open up Device Manager (Start, Settings, Control Panel, System, Hardware, Device Manager)
3) Find Samsung UP-Y3 in the list (should be under "Other" or "Portable devices" with a ? next to it)
4) Right click on this and select Uninstall
5) Remove the player from the USB port and plug it back in
Windows should automatically detect the device and install it's own drivers. If not, and you have a driver disk, then just install the Samsung drivers. You should now be abe able to drag and drop files onto the player using Windows Explorer. Hope this solves the issue.
Cheers,
Scott
Posted on Jan 02, 2009
monkeytoast
SOURCE: Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Posted on Aug 01, 2009
Samsung yp-u5 4gb connection
Use a toothpick to clean out the lint in the usb connector. If you use the mp3 player a lot without the cap lint will build up and cause misalignment when plugging it in the pc.
Apr 08, 2012 | Samsung YP Audio Players & Recorders
How can I delete songs from my Samsung YP-U3 MP3 Player?
  • 1 Turn on your computer. Connect your Samsung MP2 Player to your PC via the USB cord. Power on your Samsung MP3 Player.
  • 2 Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • 4 Right-click and select "Delete."
  • 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Mar 02, 2011 | Samsung YP-U3 MP3 Player
    My Samsung YP-S2 Mp3 player can't be recognised by computers when I plug it in through the usb input (it used to work), therefore I'm not able to upload music on it anymore. How can I fix this bug?
    Samsung Player Is No Longer Detected By Windows XP, Vista, Emodio Or
    Samsung Media Studio.
    When your computer doesn't recognize your Samsung MP3 player, programs
    such as Samsung Media Studio (SMS), Emodio, Windows Media Player
    (10 or 11) do not allow you to transfer files to your player.
    In SMS and Emodio, the portable icon appears grayed out.
    In Windows Media Player, you are prompted to connect a device.
    Your PC may fail to recognize your player for a variety of reasons.
    To begin troubleshooting, scroll down, and then click the operating
    system your computer is currently running.
    General Operating System Information
    On Windows computers, Samsung MP3 players require at least Windows XP
    Service Pack 2. If you have an older operating system such as Windows
    2000 or Windows 98, your computer won't recognize your player until you
    upgrade your PC to at least Windows XP Service Pack 2.
    If your PC is running Linux or MAC, it will not recognize some MP3
    players that support only MTP mode. However, it will recognize players
    that support UMS mode and list them as mass storage devices.
    The following Samsung MP3 players support UMS: YP-U1, YP-U2, YP-U3,
    YP-U4, YP-U5, and YP-S2.
    The following Samsung MP3 players support both MTP and UMS mode: YP-Z5
    and YP-P3.
    Windows Vista may fail to detect you device if the player is not
    connected properly, Windows Media Player is not installed or has become
    corrupted, Vista is unable to install the MTP drivers, or the MTP patch
    is not installed.
    You can check it out further by going to this website and entering the information about your player
    http://www.samsung.com/us/support/#
    Please rate me.
    Jan 15, 2011 | Samsung YP-S2 MP3 Player
    Reformat the mp3 player yp-s2
    While connected to the PC, go to my computer. Right Click on the USB Audio device (mp3 player) and choose Format. It will now format your player. Just make sure to back up your files first as to formatting will restore your player to default settings and will wipe out the memory.
    Thank you for using Fixya!
    Jan 03, 2011 | Samsung YP-S2 MP3 Player
    I have a samsung yp-u2 mp3 player, but dont have the software to install or remove music on the mp3 player. I have tried the download.com and also samsung site, they dont have it either.
    You don't need that actually. The computer will just recognized this as removable drive. Open up My Computer then plug the device on USB port, then it will pop up as removable/additional drive. Explore, then goto folder or file folder usually MUSIC folder or where you put the music files.
    You can drag and drop MP3 files and delete it. Software dismount it and take off and you are ready to play it.
    Hope this helps you.
    Nov 06, 2009 | Samsung YP-U2X Digital Media Player
    How do i delete songs from my samsung yp-u3 mp3 player
    Greetings, Step 1 Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.
    Step 2
  • Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • Step 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • Step 4 Right-click and select "Delete."
  • Step 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Sep 26, 2009 | Samsung YP-U3 MP3 Player
    I can'y delete the folders on my Samsung YP-T9J
    On my YP-T9 I choose format and it deletes everything. Of course, I don't use it for pictures, videos, etc. You can format it either with WMP, Samsung Media Studio, or Windows Explorer. Only takes a couple minutes -- in fact, it's a lot faster than deleting the songs via WMP Sync.
    Dec 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
    NEED HELP
    Take out the USB from the MP3 Player. Connect it to your Computer. Go to "My Computer" and go to where it says "Portable Devices". Under where it says, "Samsung YP-U3". Double Click and Double Click "Samsung Flash Media". Double Click "Music". And put MP3 Songs, to the folder. Now it's ready to listen to it.
    Thank You for Using FixYa!
    Good Luck with your MP3 Player!
    Oct 29, 2008 | Samsung YP-U3 MP3 Player
    How do I delete music from my SAMSUNG K3
    Ezy! Open Start menu -"My Computer" and you'll see the YP-K3 player sitting there as a removable device. Now click it and then click Media folder, then Music folder. In there U can easily delete your music and/or add music by copying/pasting INTO that folder.
    Hope it helps...
    Andy
    Dec 03, 2007 | Samsung YP-K3 MP3 Player
    How to paste a sme firmware download file to "ROOT" of my yp-t8
    Ok you need to know exactly what model number player you are using as there are three versions of the YP-T8. * YP-T8A * YP-T8X * YP-T8Z Once you know that then you go to the samsung site and download the appropriate driver. Looks something like this: FM/200611/20061107201844343_YP_T8_ROM_20060609_138US.zip Once you do that you have to unzip or extract the file. Windows should do this automatically. According to the directions you then take the files that it unzips and put them on your mp3 player. So connect your mp3 player to the computer via that usb cable. It should show up as a Removable Device under My Computer. Find the files you just extracted. Should be YP_T8.fnt, YP-T8.rom and YP-T8.img You then simply copy those files into the mp3 player which is that new removable device drive. The root folder is the first area you see when you first explore the drive. i.e. any folder you see on that mp3 player when you double click on it is actually a sub-folder and not the root folder. So open it up and copy those files right there. After which you then do as the directions say. Unplug the mp3 player, power it off and then connect your charger. It says it will automatically upgrade the firmware and then automatically turn on so it should just be a waiting game at that point. Good luck!
    Sep 26, 2007 | Samsung YP-T8 Digital Media Player
    Samsung YP-S2 MP3 Player Logo
    Top Samsung Audio Players & Recorders Experts
    Electro Med Services...
    Electric Dime
    Electric Dime
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
