Question about Kenmore 8,000 BTU Single Room Air Conditioner
Model 263-79081 How do I remove vents to clean
Model 263-79081 How do I remove vents to clean them?
My estate dryer model #eed4400wqo
I suppose you want to clean the lint vent to outside. Clean out the filter first by removing the manual filter and pulling off all stuck lint. Try this link to clean the vent:
How to Clean Clothes Dryer Vent
Feb 12, 2015 | Estate Eed4400wq 29 6.5 cu. Ft. Electric...
How to clean the cooling vents on my Whirlpool Model GB2FHDXWB
Dust and other debris can be removed gently with a vacuum cleaner and a soft brush and cloth. You can purchase several different attachments/brushes specifically designed for hard-to-get-at coils.
How to: Refrigerator Parts Cleaning
Jul 20, 2014 | Whirlpool Refrigerators
DRYER IS HOT BUT CLOTHES DONT DRY I CLEAN THE LINT EVERY LOAD
Remove the vent tube at the back run it with that off... If the cloths dry ok then you have a clogged vent Buy a dry vent cleaning kit and clean it out of call a professional to do it.
If that does not help then you will need to do more trouble shooting.
Please provide the make and model number of your appliance when asking questions
Jun 07, 2011 | Dryers
The dryer is taking 2-3 full cycles to completely dry the clothes. I have already unplugged the dryer, checked the hose, completely cleaned it of any dirt that was clogged a little. Also used the vaccum...
if you have heat in the dryer you have a blockage somewhere in the dryer or the vent line,how long is the vent line?also try removing the vent line from the back of the dryer and run it to see if it dries,i had a guy tell me he cleaned the vent line,i stuck a leaf blower in the vent line and blew out a birds nest.also check the outside duct,if there's a cage or screen on it remove it and keep it off and then blow out the line. also the duct that the lint filter slides into should be removed and cleaned.send the model number so i can look up your machine,if it's gas you could have bad gas coils,they work fine until they heat up like 15 to 30 minutes then no heat until they cool down and then they will work for a few minutes and stop again,send model number off of the dryer,open the door and look around the opening,you should see a tag with the model and serial number.
Mar 26, 2011 | Dryers
Maytag Model PYE2300AYW Heats for short time
In most every case i have seen this happen, the dryer is connected to flexible venting. Flexible venting is the worst thing for a dryer. Rigid aluminum only. If your element shuts down that fast, it is definitely an air flow problem. Remove the front, clean out the lint screen housing from the spout to the blower, all the way to the lint screen so that it looks factory clean. The venting must be absolutely clean as it was the day it was put in new. The outside application, whether it is louvers, vent flapper, or ball vent, must be clean and operable as a new one. Once again, my suspicion is the venting as it is most likely a flexible type of venting with either excessive length or restricted flow. A dryer can only be vented for 30 ft. counting 5ft for every elbow and 5ft for the outside application. But the flexible equates as this...for every 1 foot of flex you must add 5 foot because of air restriction. I am surprised that the non resetable fuse has not blown yet. ( it will, trust me.)
Mar 31, 2009 | Maytag PYE2300AY Electric Dryer
Clean vent
The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
Dec 21, 2007 | Microwave Ovens
Vent cover removal from Kenmore 17252 dishwasher door, for cleaning
kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
Feb 06, 2007 | Kenmore 17252 Free-standing Dishwasher
Kenmore 8,000 BTU Single Room Air Conditioner Logo
57 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
