Question about Solis Coffee Makers & Espresso Machines
Solis 110 remove top,how? - Solis Coffee Makers & Espresso Machines
Solis typ 110
Here's a link to the user's manual online. I'd try looking through that first. If that doesn't help, we're still here for you. Good luck
http://www.solis.ch/pdfs/manuals/BDA_espr_maschine_f.pdf
Mar 30, 2014 | Coffee Makers & Espresso Machines
Steam works intermitantly, how do you get top off machine? Ive removed the one top screw but top doesn't want to come off. I have a solis crema sl-90. thanks!
Hi
Once you have the screw out, the top will slide forward. Don't try to pry the top up or you will break the mounts. The face will move with the top as they are connected. When you put the top back, the face slips into a grove in the top and everything slides back.
Feb 28, 2010 | Solis Crema SL-90 Espresso Machine
My Solis master 5000 leaks water from the removable water decante
Hi
On top of the machine under the water tank is a doughnut cover. Pry the cover up and it should pop off. There is a black seal in the center that will shrink over time with calcium and that just needs to be replaced. When you go to replace it it will not slip in. You need to run your finger nail around the bottom of the seal to get it in. Then it will push down. Flat part of the seal up.
Dec 12, 2009 | Solis Master 5000 Espresso Machine
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
My Solis Pro Coffe m/c is showing a constant out of water light
Hi
Your probably missing the magnet in the water tank.
May 03, 2009 | Solis Master Top 517
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Good luck and Best wishes
Lane
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Service solis master pro
Hi
Contact Quality Coffee Systems in Burnaby, BC qcs@telus.net
Dec 18, 2008 | Solis Master Top 517
Manual for Solis Master Top 517 Problem
Dear Sir/Madam,
My Solis 517 is not working at all. I get few lights on the front panel but pressing buttons nothing happen.
Can you please tell me what I can look for or what do you think is the problem.
Thank you
Your truly
Joe
Nov 30, 2007 | Solis Master Top 517
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
