Question about Tiger Hasbro/Net Jet Instant-play Online Game System
My netjet won't install from autorun - Tiger Hasbro/Net Jet Instant-play Online Game System
Telling me to go to netjet support site
Having trouble getting it to work on my computer
Aug 04, 2013 | Tiger Hasbro/Net Jet Instant-play Online...
I recently purchase a emac for my daughter, it's
Hi, unfortunately not every accessory that you can use for windows based pc's is good for Mac platform. This is why when you click on Autorun.exe the Mac won't install anything and won't work.
You should check if the device you want to use is Mac compatible. If you don't have the original package you should go to producers website and search for your device compatibility list.
If your device is not designed for Mac paltform you have to buy another device Mac compatible.
Let us know if you solved your problem
May 16, 2011 | Apple Computers & Internet
I have windows os and there is a autorun.inf something hidden file in my all drives.my avira antivirus has blocked that file.and i want to know that is the file safe or it is going to harm my pc.what...
Autorun.inf is the primary instruction file associated with the Autorun function. Autorun.inf itself is a simple text-based configuration file that tells the operating system which executable to start, which icon to use, and which additional menu commands to make available. In other words, autorun.inf tells Windows how to deal open the presentation and treat the contents of the CD.
That being said, it would depend on what it is trying to run automatically. If it is trying to run iTunes automatically that is one thing, but if it is running a virus automatically it would not be safe.
You can right click on the file, and edit it with notepad/wordpad to find out what program it is trying to run.
May 02, 2011 | Computers & Internet
I can't delete the autorun.if even if i already followed the steps {using the run box}
Hi, you can use the Autoruneater software to eat the Autorun.inf files in the computer.
Please download and install the Autoruneater from the below link, it's free!!!:
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
Autorun.inf files are the files which are written to run the programs automatically like CD/DVD games have it to launch the installer automatically.
Mar 26, 2011 | Computers & Internet
How to intall game driver parallel lines
When you put the disc in an Autorun should come up asking you to install, after clicking install you should follow the instructions displayed on screen.
If the Autorun doesn't display go to My Computer, right click on the disc drive, and select Autorun to bring it up.
If this doesn't work right click on the disc, click open, then find the file 'setup.exe' double click this and the installer should launch.
Mar 01, 2011 | Video Game Consoles & Games
How do i remove autorun virus?
Hi dear, you can remove your autorun virus without anti-virus just follow my instructions.
>>>> Open your command prompt and give these commands; for example if you have only one drive
>>>> D:/>attrib -s -h -r autorun.inf (and then press enter)
>>>> D:/> del autorun.inf (and then press enter)
Now take a reboot and after rebooting autorun virus will have been removed.
Note: if you have more than two drives you should change with D: like E: or F: or G: etc. and then give this command again and again for each drive and in the end take a reboot.
Now your drives have been cleared from autorun virus.
Good Luck
for more information you can contact me back.
Jan 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Startup programs sometimes late
The reason for start up programs running late is because there are more programs installed in the computer and it takes lots of time to get these programs to run during startup. Some of these programs are not too useful but will always delay a computer startup. More and more people are becoming aware of how important it is to take control of the "autorun" programs on their PCs. In case you didn't know, an autorun or startup program will launch automatically when Windows starts. Quite often, it's a useful program and you can find it's icon in the system tray. However, sometimes an autorun is not that useful. You may not know it's installed because it's hidden or you've forgotten you installed it. When that happens, these not so useful programs are taking up processor cycles and eating up system memory. Your PC gets slower as more hidden programs are launched as an autorun. Fortunately, there are several ways to take control of the autorun programs. Windows has a utility built in called "msconfig", and there are also quite a few third party autorun apps such as this one: Autoruns by Sysinternals. Autoruns is offered for download as a ZIP file. To install it, extract the ZIP file to a folder somewhere on your PC. You'll see the following four files in the folder. lonerangerx7.png
Double click the "autoruns.exe" file to launch the program. Here's a peek at Autoruns in action. lonerangerx7_0.png
If you find a program you aren't familiar with, you can right click on it and choose the "Search Online" task. That will open your web browser and send you to the search results for the file or process that you have highlighted. In order to stop a program from running at startup, you can remove the little check-mark beside it. The interface may look confusing at first, but if you run into any problems, you can always consult the built in help from the top menu. I hope this explanation helps in solving your problems
Dec 15, 2010 | Computers & Internet
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Apr 01, 2009 | Microsoft Windows XP Home Edition
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
Tiger Hasbro/Net Jet Instant-play Online Game System Logo
60 people viewed this question
Top Tiger Video Game Consoles & Games Experts
Vickie McMinn
Vickie McMinn
Level 1 Expert
Are you a Tiger Video Game Console and Game Expert? Answer questions, earn points and help others
